Reverse problem in my 2002 Powerstroke
Old Jul 28, 2020 | 02:23 PM
realdann's Avatar
realdann
4th Gear
Angry Reverse problem in my 2002 Powerstroke
Forgive me for hi-jacking this thread. I am hoping that Mark will respond.
I have a reverse problem in my 2002 Powerstroke. The tranny was rebuilt about 100,000 plus miles ago. What is happening is when I place the truck in reverse, when the truck is pointing down hill, and attempt to back up, something is binding. The truck does move backward but it wants to stall the engine. On flat ground or pointed up hill no problems. Other than that the transmission functions perfect. Is there perhaps a clutch pack that has more space in it than it should, which is allowing a disk to fall towards the front of the truck when pointed down hill?
Thanks,
Old Jul 28, 2020 | 06:59 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Thanks,
You'd do much better to start your own thread instead of hijacking a thread.
Old Jul 28, 2020 | 08:18 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
@realdann , I have saved you the trouble of creating your own thread by doing that for you.
Good luck with your 4R100 issue!
Old Jul 28, 2020 | 08:54 PM
Mark Kovalsky
The problem is low trans fluid. Fill it up and the trans will be fine.
D_Dillen
Mar 18, 2011 05:17 AM
SouthernBlues
Mar 14, 2010 06:55 AM
5. Slow
Jan 6, 2010 12:14 PM
zacherrin
Oct 7, 2006 12:56 PM
smallblock351w
1983 - 2012 Ranger & B-Series
Oct 6, 2006 01:17 AM
