E4OD Grinding and stalling in reverse
Old Nov 22, 2009 | 06:39 PM
5. Slow's Avatar
5. Slow
Hi
I recently bought a 96 F-250 powerstroke 2wd. Before i bought it the owner said the truck stalls when you put it into reverse and give it gas right away it stalls. She said you have to wait a couple seconds. When I test drove it, I did that and it was totally fine.
A couple days after I had it and drove it around, I put it into reverse and the engine made a bogging down sound and was about to stall. When i continued in reverse it was chugging, then started to make a grinding noise from the trans. Put it park then in reverse again and it was fine. I did the reverse procedure again and then it stalled.
It seems to be worse when the truck is fully warmed up and been driving for a while. When it is cold, the reverse doesn't do this.
HELP!! What could the problem be? Thanks for any input
Btw, the trans was reuild 12k miles ago
Old Nov 22, 2009 | 08:39 PM
f100guy's Avatar
f100guy
look at the thread i posted up about the e40d write up. it mentions this problem.
Old Jan 6, 2010 | 11:02 AM
fordjunkie1976's Avatar
fordjunkie1976
1991 e4od reverse problem
heres the problem the truck works great in all forward gears if u idle it in reverse it will move if you gas it it feels like the brake shoes are locking up and the engine bogs way down any ideas oh and by the way its not the breaks thanks ed
Old Jan 6, 2010 | 12:14 PM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/9...d-i-found.html Here is the writeup by f100guy.
Your problem sounds like the converter lockup clutch is locking the converter when it shouldn`t.
Have a read through the above.
JWright94
1997 - 2003 F150
Jan 24, 2017 11:48 AM
///Mink
32
Jan 7, 2017 10:23 AM
95_F2504x4_5.8
Feb 18, 2016 08:27 PM
kylechamb
Feb 4, 2016 08:15 PM
900rr
Modular V10 (6.8l)
13
Jan 21, 2007 10:01 AM
