Wait to start
Old Jul 23, 2020 | 09:15 AM
Listor's Avatar
Listor
Originally Posted by JayTheCPA
My vote is: it depends.
In theory the light should indicate when the GP's are warm enough to start the motor. As noted, they may continue to glow after motor start to help with combustion and warming the air inside the cylinder. While getting an additional light to show when the GP's have current is one way to go, and another is to just glance at the volt meter as they draw a lot of power.
From the description (and am presuming a cold start), the short 'On' time does seem suspicious to me. Waiting a few more seconds certainly will not hurt.
In practice, the amount of wait time depends on temperature (warmer = shorter). If I am starting a motor after it was shut down just a few minutes prior (example: refueling), I usually start immediately rather than wait based on the light as the motor is already at operating temperature.
I have watched mine on a cold start( first of the day, light goes out about the time my key in chime stops) so on cold morning i will wait a little longer
after it has been run up to temp It will just kinda flash, like you i will generally just fire it once shes warm
Old Jul 23, 2020 | 01:57 PM
FinnishStroker's Avatar
FinnishStroker
Heres my manual GP switch and indicator LED.
Old Jul 23, 2020 | 03:07 PM
Walleye Hunter's Avatar
Walleye Hunter
What does Hehkut mean?
Old Jul 23, 2020 | 04:21 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
It's what Keith Urban needs.
Old Jul 23, 2020 | 04:28 PM
FinnishStroker
Glow plug is hehkutulppa in finnish.
Hehkut = GPs 😀
Old Jul 23, 2020 | 04:38 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
That was a good one...
Old Jul 23, 2020 | 04:44 PM
FinnishStroker
I know Keith Urban ,but i'm not getting it..?😱
Does he need some SISU or KOSKENKORVA perhaps..?🤔
Old Jul 23, 2020 | 04:47 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Hehkut = GPs 😀
The only Finnish I need to know is what I learned from Hydraulic Press Channel.
Old Jul 23, 2020 | 04:48 PM
Walleye Hunter
Haircut is a thing we get at the barber shop. And I'm about due myself.
Old Jul 23, 2020 | 04:49 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
I figure that you probably pronounce "Hehkut" differently than we native english-speaking types. To me, it's pronounced like an Australian would pronounce "Haircut" (dropping the "r" and replacing with the short "a" or "eh" sound).
Old Jul 23, 2020 | 05:44 PM
AllaboutMPG's Avatar
AllaboutMPG
So how much pressure does it take to crush a Prince Rupert's Drop???? They really can break some stuff
Old Jul 23, 2020 | 06:01 PM
FinnishStroker
I figured the haircut from Mark's hint..🤓
Some good " Rally English",in that Channel! 👌
Old Jul 24, 2020 | 01:32 AM
  #28
Austin Burnard's Avatar
Austin Burnard
I’m gonna take a video of my dash when I can On initial start up so you guys can see exactly what I am working with.
Old Jul 24, 2020 | 04:46 AM
  #29
Wes444's Avatar
Wes444
Not sure about the others, but my glow plugs don't even come on until the wait to start light goes off. So if you don't have a digital volt meter or LED indicator mod, don't start blindly counting seconds until after the light goes off. In the winter if you start cranking as soon as the light goes out the glow plugs are just starting to get juice and won't be hot enough to really help at all for a good 10 more seconds, which ironically is after the fuel pump times out and shuts off...
Old Jul 25, 2020 | 08:32 AM
  #30
MoBill122's Avatar
MoBill122
Papa Smurf
As old as your truck is now, I'd just pull the cover and replace all the lights. Not that hard of a deal. Especially if you have so many non working lights, you can't see the instruments at night.
chief915
Jun 10, 2012 09:56 AM
mike.head
Oct 17, 2011 04:57 PM
JumpinJoe
Apr 17, 2009 06:22 PM
