Weight distribution hitch
Old Jul 14, 2020 | 05:41 PM
  #31
67L48's Avatar
67L48
Originally Posted by Bootlegfab
[...] rough estimate of 8000lbs wet with a wet tongue weight of 800lbs. I pack light and again these are estimates. [...]
For a conventional tow trailer, 10-15% is the recommended weight on the tongue. So, you're on the light end of the scale. I'd expect that with normal loading on a trailer like that will be in the 12-14%. Thus, I'd figure around 1,000 lbs on the tongue.
I like the WDH for sway control. That alone is worth it.
I use Equal-I-zer 4-pt and it's worked great. My F-350 doesn't really need much in the way of weight distribution for my 26', 6,800 lb trailer, but the sway control is stellar.
Old Jul 14, 2020 | 06:10 PM
  #32
BroncoRN's Avatar
BroncoRN
Originally Posted by chief1232
I ended up ordering an Andersen this week for my trailer. I will let you know how it goes.
I wanted an Equalizer, but they don't have a 3" shank out (Yet). I did email them, and they said they have one in the works, but no ETA on delivery. If i'm going to spend $800+ on a hitch, I'm not going to buy something that I still need a sleeve for...
I use the hitch clamp. I would be using a reducer with 2.5” shank anyway. Locktite on the nuts and now it’s rock solid.
Got my Equalizer on Craigslist for $100.
Old Jul 14, 2020 | 07:45 PM
  #33
Justvisiting1's Avatar
Justvisiting1
So the equalizer does seem like the one everybody likes.
got the truck, still need the TT.
so give me some opinions on why some of the weight distributing hitches say you can reverse with them and some say you can't.
can you with the equalizer,?
I'm not against hopping out of the truck to unhook a few things so I can back up.
but was just wondering...
Old Jul 14, 2020 | 08:04 PM
  #34
Bill Tex's Avatar
Bill Tex
You can reverse and fully jackknife with Equalizer. No problem at all. It may creak and pop sometimes, but other than that it is set/forget.
Old Jul 14, 2020 | 08:08 PM
  #35
Justvisiting1
Cool, thanks
Old Jul 14, 2020 | 08:46 PM
  #36
dieseldrive's Avatar
dieseldrive
Not needed
2019 F-250 without camper package. Just picked up a 27’ Starcraft travel trailer which supposedly weighs 6500 dry with a dry tongue weight of 650. 2200lb capacity so rough estimate of 8000lbs wet with a wet tongue weight of 800lbs. I pack light and again these are estimates. I have airlift 5500 bags which I know don’t help with the front axle being weighted, but will help with the inevitable sag on a leveled truck. I assume I will want a weight distribution hitch to help add weight back onto the front axle as well as prevent sway. Can anyone recommend a specific hitch? I’ve googled and watched YouTube at length and still find no real reason to pick one over the other. I know I’d like the weigh safe true two because it’s a clean and slick looking hitch but at $999 when most others are $500-600...it’s a hard sale when I still need to buy a generator. Thanks in advance for any recommendations
D
I recommend that you try towing that trailer without a WD hitch. You really shouldn’t need it for that size/weight trailer. These trucks are already heavy on the front axle (especially a diesel) and 800 pounds on the ball is nothing. There is such a thing as removing too much weight from the rear axle - the rear tires need some weight on them.
Old Jul 14, 2020 | 08:52 PM
  #37
HRTKD's Avatar
HRTKD
I haven't encountered a WDH you can't backup with. Maybe that's really old school WDH?
The Anderson WDH weighs half what most spring bar type WDH do. Many spring bar WDH require you use a bar to attach the chain, which requires force. If you slip, the bar can come back and whack you a good one. It's unlikely, but possible. The Anderson doesn't have that type of configuration issue. Since you have a Super duty, the Anderson would be ideal for your truck.
Old Jul 14, 2020 | 09:08 PM
  #38
BroncoRN's Avatar
BroncoRN
The WDHs with bars and chains don’t work really well backing up. Equalizer won’t pop or creak if you keep it greased.
Old Jul 14, 2020 | 09:11 PM
  #39
BroncoRN's Avatar
BroncoRN
It would be more for sway control. On my dually I have it set at base setting with 5 washers and brackets set in the middle and it works perfectly.
Also that 650lb tongue weight is way off. They don’t include 50lb battery, 80lbs for propane, or your stuff in forward storage. If you added another AC consider that as well. So figure about 1,000 lbs for tongue weight.
Old Jul 14, 2020 | 09:18 PM
  #40
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
I have used the Reese Dual Cam WDH for a decade and a half, and never had any trouble backing up with the WDH engaged, and it consists of bars with chains.
Old Jul 14, 2020 | 09:21 PM
  #41
HRTKD's Avatar
HRTKD
My Blue Ox Sway Pro had bars and chains. I backed that thing up without any issues. Maybe there was a problem and I didn't know about it.
Old Jul 14, 2020 | 09:23 PM
  #42
BroncoRN's Avatar
BroncoRN
Not the dual cam, think more like regular Reese WDH. Dual cam is different animal those extra arms keep things in line. Plain Jane WDH try to twist and move when you back up and turn. They don’t stay in line with trailer tongue if you cut it to hard.
You can make it work with a mild turn or backing straight.
Old Feb 18, 2021 | 10:58 PM
  #43
sstock1's Avatar
sstock1
Diesel Drive's post up above nails it if you ask me, On lighter to medium weight travel trailers with large profiles that catch wind, a friction sway control bar should be considered in lieu of a weight distribution hitch IMHO. Earlier post mentioned that it is good to carry some hitch weight especially with super duties. We are not driving half tons here guys and these trucks are designed to carry weight. A thousand pounds of hitch weight is really of no concern on my F350. I have a 15K gross weight dump trailer that I tow around fully laden and it is done without a weight distribution hitch. If sway control is the problem then suggest looking at a friction type sway control bar like this one: https://www.summitracing.com/parts/c...caAnAAEALw_wcB
If you find yourself bouncing down the highway when you go over small bumps that are unloading the rear suspension and sending the weight to the front suspension then you need to consider a weight distribution hitch. Otherwise I wouldnt be too concerned with it. My .02 only
Old Feb 19, 2021 | 08:52 AM
  #44
Bootlegfab's Avatar
Bootlegfab
Thumbs up
Thanks for the replies all. The most recent reply reminded me of this thread and I thought I’d check back in after I’ve towed the trailer a bit. I ended up with the Equalizer and couldn’t happier. I get no proposing, run 10 psi in the bags (hitch setup to work with the bags) and the sway control is great. Thanks again for all the input.
Old Feb 19, 2021 | 09:38 AM
  #45
empire_designs's Avatar
empire_designs
I have used a few different hitches on different trailers. With the most recent bumper pull toy hauler that's roughly 35', we went from a Curt WD with friction sway device, to a 14k Equal-i-zer. The difference the equal-i-zer made was amazing, but due to the length of the trailer as well as the added toy weight in the rear, still caused sway magnification with cross winds and semi's. We've since moved to a Pro-pride 3p with 1400lb bars. Let me tell you what a world of difference the pro-pride makes. It is truly unbelievable the difference the pro-pride makes.
In most situations, dependent on length and weights, I would say that the equal-i-zer is a great option and really reduces the amount of sway you will encounter for an affordable price. I will also say, from my experiences, the pro-pride truly eliminates sway. In my particular situation, pulling a $40k toy hauler with $25K toy inside, in a $70K truck, with a priceless family inside, a $2000 hitch is an easy decision.
TRHOD121
Oct 10, 2014 08:39 AM
Ferguson65
All Things Towing
Mar 25, 2007 07:47 AM
dana_wildcat
All Things Towing
Jul 29, 2005 09:19 PM
bkvanbek
Jul 2, 2004 06:58 AM
SmittySD250
All Things Towing
Sep 23, 2003 01:08 PM
