Sponsored by: Real Truck
Hitch capacity?
Old Jun 26, 2004 | 07:34 PM
bkvanbek's Avatar
bkvanbek
Hitch capacity?
I got the Ford receiver hitch on my 2003 F-350. What is it's capacity? It says something about 1500# weight distributing and 6000# something and 600# tongue weight. So what can I pull?
I pulled an 8000# skid steer and trailer, I hope this was okay?
Old Jun 26, 2004 | 07:54 PM
johnsdiesel's Avatar
johnsdiesel
The 600/6000 is for a regular hitch (weight carrying) and the higher numbers are for a weight distributing hitch. 8000 without a weight distributing hitch is over the capacity of the receiver. The weight distributing setup redirects some of the tongue weight to both the front axle of the truck and back onto the trailer.
Old Jun 27, 2004 | 01:08 AM
bkvanbek's Avatar
bkvanbek
When you say weight distributing, that means 5th wheel I suppose? But I see all kinds of 1-tons pulling skid-steers and other heavy items. What do I have to do to pull a 10,000# trailer?
Old Jun 27, 2004 | 01:39 AM
johnsdiesel
No, a weight distributing hitch works in a frame mounted receiver. HERE is a link that demonstrates how they work. This is what you need to pull a 10K# trailer with your current receiver. You could always get a receiver with a higher weight carrying capacity, but Ford recommends (and so do I) that you tow anything that heavy with a WDH.
Old Jun 27, 2004 | 08:57 PM
cahook's Avatar
cahook
This is a good thread to ask my question in. The 2005 SD's says that it has a towing capacity of 17K. My owners guide says my 250 SD only has a capacity of 10K. What are the differences between them that change the towing so much?
Old Jun 27, 2004 | 10:31 PM
johnsdiesel
I think the frame has been strengthened, but I don't know what else. The 17K is for a fifth wheel I believe. Is the 10K also for a fifth wheel or for a regular trailer?
Old Jun 28, 2004 | 12:09 AM
cahook's Avatar
cahook
The owners manual doesn't mention a 5th wheel. I believe that the rating it for a standard class III/IV hitch. The 5th wheel should get you a little more I thought. 12 -15K
Old Jun 28, 2004 | 07:00 AM
bkvanbek's Avatar
bkvanbek
I don't completly get it. So it is not the strength of my factory hitch, it can hold 15,000#, but without sway control it shouldn't be done?
The weight distribution, of a WDH, can only affect tongue weight right?
Old Jun 28, 2004 | 07:09 AM
rmilchman's Avatar
rmilchman
I don't think a class III/IV hitch can hold that kind of weight (going by industry standard numbers). I would think you would need something stringer then a calss V.
Old Jun 28, 2004 | 07:21 AM
bkvanbek's Avatar
bkvanbek
ya, my f-350 has a class 5 hitch. It says it can hold 6000/600# or 15,00 with weight distribution.
Old Jun 28, 2004 | 07:33 AM
philips's Avatar
philips
I just received my new 2004 F250 in May. I researched this hitch deal before ordering. The Ford hitch is worthless to the avereage person who tows much of anything. I think the 6K WC rating is due to conservativness, liability, and laywers. I did not order the Ford hitch on my new truck, instead I installed a Draw-Tite ultraframe hicth that is rated 1K/10K WC and 1.2K/12K WD. I tow 6K to 10K antique tractors on a regular basis in the warm weather months, and if I set my weights up correctly, I do not need a WD hitch. Philip.
Old Jun 28, 2004 | 09:10 AM
johnsdiesel
The Ford hitch is not worthless to most people. If you follow Ford's recommendations you should be using a WDH for anything over 6K anyway. The Ford hitch could handle your load just fine. The only people who run into trouble are the ones who tow boats with surge brakes and can't use a WDH, but that's not the majority of owners.
Old Jun 28, 2004 | 09:33 AM
hotrod4x5's Avatar
hotrod4x5
It's not the sway control you need. It's the weight distributing hitch, which uses two bars, one on each side of the tongue, to apply leverage on the rear end of the truck thereby lifting it slightly which puts some of the weight onto the front axle.
Imagine putting a lead pipe into the receiver hole and lifting up, this would take some weight off the back end and move it to the frame and onto the front axle. this is what the hitch does. The sway control is another feature of this type of hitch. Some have integrated sway control, while others you add it on.
I tow a 4k trailer with my '02 F250 CC LB V-10 and use a w/d hitch without sway control. Why do I use a w/d hitch for this light of a trailer? Well I used to tow with an SUV and when I got the SD, I simply used the same hitch. When I hook up, the rear of my SD drops about 3/4-1 inch. the w/d bars bring it back to level. I don't use sway control because I feel I don't need it and have never had a problem with sway. My truck is longer and heavier than my 21ft. travel trailer and it tows like a dream.
Rodney
2002 F250 CC LB V-10
Old Jun 28, 2004 | 09:50 AM
philips's Avatar
philips
Where does Ford say you should be using WD for anything over 6K? I must have read over that in my manual. I see very few farmers, antique tractor hobbiest/pullers, or construction workers in my area using WD for anything under 10K. In my opinion, the main group using WD is travel trailers, who pull the same trailer with the same truck with few variables, and that is fine for them. Can you put a WD on my pintle and lunette ring tri-ax? Philip.
Old Jun 28, 2004 | 09:54 AM
hotrod4x5's Avatar
hotrod4x5
Phillips, look at the sticker on your receiver. Mine says max capacity is 5000lbs, 500 tongue, weight carrying; and 12,500lbs., 1250lb tongue weight distributing.
Rodney
