Crazy price for work? Ripped off?
Hey folks. Got a 2005 6.0 in the shop right now with some light bucking, poor acceleration and nasty idle. EGR valve was cleaned and reinstalled 1k miles ago.
The shop called and wants to do the following work:
EGR delete
Oil cooler replacement (it is leaking)
IPR valve replacement
Fuel filter replacements
ICP replacement. (I replaced 2k miles ago, so not sure about that being done.)
S belt replacement (small cracks)
They want $3,000 for all the above. Is that insane? It seems like a lot and I'm in a really tough spot. Any help would be appreciated.
EGR delete
That seems like a shotgun approach without diagnostics. I can't say that anything on that list would solve your issues.
If you want an informed answer to the issue and what should be done, this group will need data from monitoring and more history. The monitoring of the data is not expensive as long as you have a cell phone, then another $50 tops, but monitoring is something that is absolutely needed for owning a 6.0.
I'd run from them just for recommending all that. Why would anyone replace an IPR valve unless it wasn't working. And if it wasn't working, the truck wouldn't run at all. Ditto the IPR - it's possible for the truck to run with it unplugged, but why replace it if it's working? If the tech thinks it's fuel filters - and it could be although I'd expect to see smoke if so - then replace those before doing anything else and save yourself $2900. You certainly don't want to do all that work, find that it fixed nothing, and then swap in new filters to find that was the cause.
To me, it's just that all of these don't point to a single problem, or a single repair process. It's just a random list of a bunch of parts that can break at times, with one - the oil cooler - included that requires a bunch of labor for good measure. Was the truck even overheating? Why does he think the cooler needs to be replaced? Is the oil in the coolant, or is it the typical soot we all see and you're being told it's oil?
Did the guy even try to explain all this, or was it the generic - "I'm the tech, you gotta trust me, this is all the stuff you need." Unfortunately, many service businesses have decided that they make more money ripping people than being honest. If they can't rip you, they don't even want your business, so complaining does no good.
So, essentially the oil cooler has been leaking for a while and he caught that, suggesting it be replaced, and everything else be done on the way there.
I didnt fight as much as I initially thought I should because I know the cooler, egr and valve are original and wanted to replace at some point soon anyway. The price tag was just something I was unsure of, as I've never really gotten this much done at one time.
I did get an IPR code, I think it was, a while ago, but things ran fine so I prioritized other things along the way. What I'm assuming is, they saw issues along the way, and made it a "hey do it all while we are in there, or dont do it at all" situation.
So I got her back. Cost me everything I had, but it runs like a top right now. Ended up getting the following done, and all work has a 3 year, 35,000m warranty. One thing I dont get is the ECM update. I didn't catch it while I was there and didnt get to ask. See pic.
EGR bypass
S belt replacement
Oil cooler replaced
Oil change
Fuel filter
ICP sensor and new pigtail
Fuel Pressure Regulator kit
"ECM update?"
EGR bypass
S belt replacement
Oil cooler replaced
Oil change
Fuel filter
"ECM update?"
With anything, if your happy and it works, that's all that's necessary.
Most of us like to understand the faults for the repairs. The price for an ECM update is too high for a reflash, so they either replaced the FICM or the PCM. That wasn't in your original post, but if FICM it would make a better sense of your issue.
