Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
edge 8F35 transmission
Old Jun 10, 2020 | 10:05 PM
old farmer's Avatar
old farmer
This problem recently showed up on my 2019 Edge.with 2.0 liter ecoboost.
The new for 2019 8F35 transmission is surging at low speeds during warmup and to a lesser degree when fully warm.
I took it back to the dealer 2 weeks ago and they did a computer re-flash, but it didn't help. It was for harsh shifting, not my issue.
The tech said it would shift strangely for a few days until it learns my driving. It's an adaptive learning tranny.
So back it goes on Monday afternoon, so they could drive it on Tuesday morning to find out how it's acting. Of course it didn't act up.
They did a pressure test on the cooling system to see if any coolant is leaking into the cylinders, left it sitting overnight under pressure and it had no leakage.
They took it for a drive with their scanner connected and it acted up. They got no codes, checked fluid level, electrical connections and anything else they could think of, and all was ok. The tech said it seemed to be hunting for the right gear, or locking and unlocking the torque converter.
So then they took a new leftover 2019 with the same engine and tranny off the lot for a drive and it acted up too.
So now they don't know what to do, and will call the hotline and ask for help from the engineers.
Has anyone else had this problem with their Edge, and has your tech found a solution?
I'm not a mechanic but it seems like a programming issue to me, like max fuel economy is what the computer is trying to achieve, but too much so.
Thanks.
Old Feb 4, 2021 | 12:03 AM
Thomas Emilio's Avatar
Thomas Emilio
Ford Edge
I have a 2020 with a go fish tranny also
Old Dec 27, 2022 | 02:17 AM
Gregor84Edge's Avatar
Gregor84Edge
1st Gear
Hi, I got the same issue in my 2019 2.0 Edge, Have you found and fixed it by now?
I thought I need to flash the adaptive learning memory after previous owner....
Thanks in advance for sharing.
hillbilly1025
Crossovers
Aug 13, 2013 07:52 AM
stx4x4
2004 - 2008 F150
Mar 15, 2008 06:18 PM
strokin'_tatsch
Feb 24, 2008 10:51 AM
bassaway
2004 - 2008 F150
Nov 22, 2007 12:25 PM
2003 Stroke
Apr 2, 2004 08:21 AM
