The numbers on my 2011 F150 Key less entry door pad are worn out, I know where the numbers are but I just want the key pad to look better, How do I remove the key pad and can I replace just the soft clear plastic cover that has the numbers on it, Do I need to remove the inner door panel or can it be accessed by removing the 2 plugs on the inside lock face of the door
OK...I found out how to remove the inside door panel and all I need now is to find out if I can replace just the soft plastic numbers button cover that has the numbers written on it, my keypad works fine it is just the numbers are worn off
On my truck the keypad is mounted in the door handle bezel and it is hard wired, I just ordered a complete actuator assembly from Tasca Ford for $50.97 including shipping
