keyless entry doesn't work
Old Jan 25, 2007 | 08:17 PM
seircrosby's Avatar
seircrosby
Just wondering how to service the keypad. I touch the keypad and get no response at all. no light or lcking or unlocking. thanks.
Old Jan 25, 2007 | 10:10 PM
EpicCowlick's Avatar
EpicCowlick
Does the keypad light up after you open and close the door?
Old Jan 26, 2007 | 07:46 AM
DMB's Avatar
DMB
Corrosion on the contacts inside the keypad is a fairly common problem. Remove the door panel, disconnect and remove the key pad from the door. Separate the plastic housing on the keypad and clean the contacts (fine sandpaper or scotch brite pad works well). Reassemble and it should function normally. Some also put a silicone bead around the seam on the plastic housing to keep moisture from getting in. Took about 20 mins on my 01, went from not working at all to like new.
simplywebb
2004 - 2008 F150
Mar 18, 2014 06:02 PM
ogbobbyjohnson
1997 - 2003 F150
Feb 11, 2012 09:47 PM
amkkba
Jun 5, 2010 05:48 AM
tkiner
2009 - 2014 F150
Jan 11, 2010 01:27 PM
3KIDDAD
Jan 17, 2007 09:13 PM
