What's wrong
Old May 25, 2020 | 04:50 AM
David Webber's Avatar
David Webber
What's wrong
I have a 1995 PSD f350. Shifts horribly. Speedometer and odometer and cruise control doesn't work. It shifts very hard and/or high rpms to shift. But h tachometer works and everything else in dash cluster works great. ???HELP Please!!!!???
Old May 25, 2020 | 06:13 AM
seville009's Avatar
seville009
For the shifting issues, I’d start by checking the transmission fluid.
For the other issues, I’d start with checking the fuses
Old May 25, 2020 | 07:08 AM
97-psd's Avatar
97-psd
There is a sensor in the rear axle. It sends input for the speedometer. If it is not working it can cause the symptoms you are describing.
Old May 25, 2020 | 07:09 AM
97-psd's Avatar
97-psd
And welcome to FTE!
Old May 26, 2020 | 02:36 PM
kameronth's Avatar
kameronth
Most likely VSS or PSOM. With the speedo & odo not working, I would lean towards the PSOM.
nukesul
Feb 21, 2018 06:15 PM
arkredneck
Oct 27, 2011 04:53 PM
05superv10
18
May 2, 2009 12:57 AM
1969goat
Sep 15, 2004 04:32 PM
73Thing
May 8, 2003 05:52 AM
