95 Windstar, TCM?
Old May 5, 2003 | 09:54 PM
73Thing's Avatar
73Thing
95 Windstar, TCM?
Ok, heres my dilemma. I recently purchased a 95 Windstar with a shift problem. It likes to downshift when you let off the gas. This is a sporadic problem. Other related symptoms (I think) are inop speedo and cruise control. In previous experiences, I have found similar problems related to a TCM, or Transmission Control Module. Is my Windstar equipped with one? Someone also once suggested a range sensor? I'm open to any and all input. Would be greatly appreciated. Thanks in advance,
Old May 6, 2003 | 08:35 AM
c96drumm's Avatar
c96drumm
95 Windstar, TCM?
Don't know that much about Windstars, but with the speedo and cruise inop, I'd check the vehicle speed sensor. The computer probably uses info from that to tell the tranny when to shift.
Just my guess...
Old May 6, 2003 | 05:08 PM
73Thing's Avatar
73Thing
95 Windstar, TCM?
Just my guess...
Yeah, that was my first guess, as well as the previous owners. It has been replaced, and it didn't fix anything
Old May 7, 2003 | 12:21 AM
Racerguy's Avatar
Racerguy
95 Windstar, TCM?
The Windstar doesnt use a TCM. All the controls for the transmission are in the PCM...Powertrain Control Module...the main computer for the engine, transmission etc.
And yes the speedo etc has to work for the transmission to shift properly. The VSS is a real pain to get at......it is on the back, passenger side of the transmission, behind the engine, on top, near the R/F axle, and usually covered with a heat shield.
Old May 7, 2003 | 08:10 PM
73Thing's Avatar
73Thing
95 Windstar, TCM?
Yeah, I heard a few horror stories about replacing the VSS, but I'm hoping I can eliminate that from the equation being it was replaced. Where might I find the PCM? Up under the dash? And, not sure if I follow you, but when you say that the speedo has to work for the trans to shift properly, do you mention this as further evidence of a bad VSS, or that the PCM uses a signal out of the Speedo/cluster to operate properly? Is either the PCM or the cluster a common problem, or should I suspect a bad, new VSS, or wiring even? Many thanks in advance,
Old May 7, 2003 | 08:34 PM
Racerguy's Avatar
Racerguy
95 Windstar, TCM?
The manual shows the VSS signal goes right to the PCM. I thought it went to the speedo first but i guess I'm wrong
I think that since all the problems happen at the same time it would seem like the VSS signal is bad for some reason or another. I've seen the gear inside the transaxle that drives the VSS wear out. Hopefully that isnt your problem.
The PCM is mounted in the firewall, sort of behind the R/F strut. If you remove the complete wiper cowl assembly (not as bad as it sounds) you can get at it and also access the VSS better than trying it from below.
In my experience neither the PCM or cluster is a common problem.
I think I'd be looking at the VSS and the gear for it first, then at the wiring.
Let us know what you find.
Old May 7, 2003 | 08:40 PM
73Thing's Avatar
73Thing
95 Windstar, TCM?
Well, we can definitely eliminate the cluster then. Not sure if thats a good or bad thing....I'm kinda leaning towards the gear myself at this point. This is a fairly common problem in Vw New Beetles, however it only affects the cruise. They tend to crack on these. However, on the Beetle, you can drop the frame and pull the rear plate off the diff. With axles removed, you can pull everything out, while trans is still installed (Although Vw still pays us for Trans R&R ) Don't suppose I'd get so lucky on this? Also, does the VSS include the reader gear that drops down into the diff and runs off the drive gear? Or is it a separate piece? Sorry for the blind questions, I don't even have this home yet. I just want to be ready when I do....Thanks for all your help,
Old May 8, 2003 | 12:03 AM
Racerguy's Avatar
Racerguy
95 Windstar, TCM?
Unfortunately the VSS drive gear is attached to the differential and that's the last thing that comes out when you're pulling the trans apart
The VSS has a gear on it that runs on the drive gear. It comes out with the VSS.
For more ideas you might want to stop by www.flatratetech.com and ask there too. Someone might have some more insight. I dont do much automatic work.
Old May 8, 2003 | 05:52 AM
73Thing's Avatar
73Thing
95 Windstar, TCM?
Well, thats exactly what I didn't want to hear So, I'll hope for a PCM problem now.....I try to limit my auto trans work to warranty work, and I refuse to do it at home, especially on a trans I have never tore into. Just isn't my idea of a fun weekend. And, if it ain't fun, it ain't worth messin with. This is a spare vehicle, and by no means necessary....Just picked up on a good deal (I think...) and thought I'd keep it around for trips and such. Still may, but don't be surprised if its in the classifieds in 2 weeks either....Thanks again for all your help,
Whitey Ford
3.0L V6
Sep 4, 2010 10:32 AM
billy150
Aerostar
Dec 5, 2008 01:23 AM
quent
Electrical Systems/Wiring
Sep 6, 2004 08:21 PM
GeorgeC
Jan 30, 2004 10:28 AM
GeorgeC
Jan 27, 2004 10:42 PM
