Potable water problem
Old Aug 15, 2020 | 03:07 PM
Tugboatguy's Avatar
Tugboatguy
Potable water pump
Originally Posted by HRTKD
Maintenance and knowledge are both helpful. The prior owner(s) of my trailer didn't have the sediment filter inline before the pump. When I replaced the pump last year, the filter screen was added.
I finally got around to adding a PEX check valve into the potable water system as suggested here. The problem is solved. Thanks for the help.
Old Aug 16, 2020 | 02:16 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Mine is still holding strong as well. Quick, cheap and easy fix.
TheLex
All Things Towing
23
Nov 1, 2017 10:09 PM
greentree ford
May 22, 2013 09:15 AM
scububbs
All Things Towing
Mar 27, 2011 01:20 PM
maevans
All Things Towing
Nov 21, 2007 02:39 AM
maevans
All Things Towing
May 3, 2007 04:24 PM
