Will leveling kit give me issues towing??
Old Aug 14, 2020 | 05:51 PM
bmcghan22's Avatar
bmcghan22
So I have a 2019 F-350 long bed it has a ready lift 2.5 coil front lift with bilsteins all the way around. We recently bought a 32” travel trailer with a 6700lb dry weight my concern is when I go to pick it up and tow it an I going to run into any issues or anything. Will I need to add air bags in the rear or have the leveling kit removed. Never towed noting this big and I don’t want to run into any problems.
Old Aug 14, 2020 | 11:03 PM
HRTKD's Avatar
HRTKD
You'll be fine with the F-350. You made a good choice in trucks. My toy hauler travel trailer has a much higher GVWR and tongue weight than yours does. My F-350 has no problem with it. Stock suspension. Just make sure the headlights were adjusted to account for the level.
Old Aug 16, 2020 | 11:18 AM
SMOKEPLOE's Avatar
SMOKEPLOE
HRTKD
That one wire that goes under the floor may go to your control panel for the battery condition, the panel with the tank conditions etc.
Smokeploe
Old Aug 16, 2020 | 11:12 PM
EDC8008's Avatar
EDC8008
If there is a level kit (you said a 2.5" block up front already) I will say that from actual practical. experience you are going to have more squat in the back and more unloading off the front than without. Many will tell you that no it doesn't happen, well I can tell you it does, that's what happened to my 350 when I had it, that was with a 4' lift and level kit. It always felt loose to me after that.
All you can do is measure top of the wheel to the fender both front and rear and compare how it sits and also how it drives.
Try it and see what it feels like, and don't be one of the idiots who doesn't think of others as he's driving with his lights square in oncoming traffics eyes, it's getting bad enough especially right now that I try not to drive at night as it's to aggravating.
Old Aug 17, 2020 | 07:27 AM
Gwilkrrs's Avatar
Gwilkrrs
the rear will squat when hooked up making the truck nose high as stock the truck sits level when squatted.
johnzenobia
2009 - 2014 F150
21
May 24, 2015 10:11 AM
Christofiso
2004 - 2008 F150
Oct 19, 2010 02:08 PM
markt1993
Feb 28, 2010 07:37 PM
caprang
Feb 6, 2006 10:53 AM
bones68
Jan 3, 2006 08:53 PM
