Torque Spec help
Old May 13, 2020 | 11:55 PM
TNdude85's Avatar
TNdude85
Torque Spec help
This will be kind of long, but I’m installing a leveling kit this weekend and I wanted to verify some of the specs I’ve found. If anyone can help, it would be greatly appreciated.
Shocks-
— Front upper- compress bushing
— Rear upper- 35 lb/ft
— Lower bolt- 50 or 100 lb/ft?
Upper Ball joint- 69 lb/ft
Sway Bar-
— Bracket- 30 or 35 lb/ft
— End links- 30 or 90 lb/ft?
Pitman arm nut- 350 lb/ft
Radius Arm-
— Drop bracket- 260 or 300 lb/ft
— Ala bushing- 154, 222, or 260 lb/ft?
— Front arm bolts- 200 or 250 lb/ft?
Track Bar-
— Frame side- 406 lb/ft
— Axle side- 185 lb/ft
— Track bar bracket- 95 or 129 lb/ft?
Bump stop-
— Extension- 5 or 30 lb/ft?
— Stop- 20 lb/ft
Drag link-
— At pitman arm- 148 lb/ft
— Axle- ?
Brake line-
— Axle mount- 5 lb/ft
— Frame mount- 10 lb/ft
I couldn’t find all of the torque specs with my level that I bought, so for the ones I couldn’t find I pierced them together from carli and bds. I know it’s probably overkill, but I’m trying to be a little more prepared with the truck compared to previous one. Thanks again.
P4IN COMM4NDO
18
Oct 12, 2016 06:09 PM
daveengelson
Sep 24, 2015 05:21 PM
timf150
Apr 2, 2012 03:34 PM
CobraGT40
Sep 7, 2006 05:18 AM
MrMojoRizing
1983 - 2012 Ranger & B-Series
May 20, 2002 07:16 PM
