Torque Specs...
I just did a front end leveler kit on my 1997 Ranger XLT Xtra-cab 4x4 (2" coil spacers), it looks great but it says I need to set the bolts back to factory torque specs. How do I find out what these specs are without dropping 30 bux on a clymer or haynes? I guess I need the Spring bolts, sway bar bolts, and shock bolts torque specs. Any Help is much appreciated!
p.s. I need to go get an alignment now too since the tires are just a touch out of line now, how much is that approximately?
Ball Joint Pinch bolt ======= 65 to 85
Jounce Bumper Bolt ========== 18 to 26
Axel pivot Bracket Bolts
Left axle arm =============== 83 to 113
Right axle arm ============== 155
Axle Pivot bolt ============= 111 to 148
Radius arm front bracket lower Bolt 190 to 255
Radius arm to front bracket upper Stud 190 to 255
Radius arm to front bracket front Bolts = 15 to 27
Radius arm to rear bracket Nut = 83 to 113
Stabilizer bar link nuts ======= 30 to 40
Stabilizer bar bracket bolts = 22 to 30
Spring retainer nut ========== 70 to 100
Shock absorber upper nut ===== 25 to 35
Shock absorber to radius arm nut =39 to 53
Use Caution while doing this the life you save may be yours and others.
