Head Light Bulbs
Old Dec 16, 2020 | 12:56 PM
  #46
Bonanza35's Avatar
Bonanza35
Talking about ceramic, do these brake disc stop as good as semi metallic? I am in a push to change my back brakes, DRW, and got NAPA ultra premium rotors and brakes. Didn't mean to change the subject but just sat down for a minute till I go outside and start work. thank you,
Chet
Old Dec 16, 2020 | 01:07 PM
  #47
FordTruckNoob's Avatar
FordTruckNoob
Chet
Did you mean ceramic pads? Full ceramic brakes is racecar/supercar territory.
Old Dec 16, 2020 | 01:18 PM
  #48
Bonanza35's Avatar
Bonanza35
Ceramic disc, yes. That is what I got because they were both the same price. Didn't know if one was better then the other. They are NAPA ultra premium disc for our DRW back brakes. Both had the same warranty. Not much but the rotors limited life warranty. With leaving after Christmas for the dunes with grand kids and all, I really need to do these, didn't realize they were down so far. The back rotors at least one of them is original. The other I lost on a vacation Saturday night when a disc came apart, had it fixed Sunday in the hotel parking lot. That one seems fine but both sets of disc are way down. So I am changing everything. Almost a 1/4 million miles now so it is time. I need to work of the seats next. Parts house couldn't tell me one way or the other.
Old Dec 17, 2020 | 08:25 AM
  #49
SkySkiJason's Avatar
SkySkiJason
Ceramic pads SUCK on these trucks. Miserable stopping power.
EBC Yellowstuff pads provide the most stopping power you can get from these trucks.
Drilled, slotted and otherwise molested rotors do nothing to improve braking and many fail prematurely with cracks. Rotors are disposable. Just get lifetime warranty ones from Napa.
Old Dec 17, 2020 | 11:17 AM
  #50
AUM's Avatar
AUM
This thread has a bit of steering wander...
These are the 3 wires coming out of harness near ABS on driver side and near water reservoir on passenger side. I assume these trigger the headlights. Do I need to hook both of them up to the external harness or will one side do?
Driver Side
Driver Side + Ground
Passenger Side
Old Dec 17, 2020 | 11:44 AM
  #51
Bonanza35's Avatar
Bonanza35
Thanks for jumping in, unfortunately I did one side last night. Pulled it apart then found the E brakes really bad. I drove it away a few times without releasing them so that was my fault. Went and got them and did the one side before dark. I plan on doing the other side today. So with these DRW I am going to have to run with it for a while. I did get the NAPA life time rotors. Thanks Jason. If I had time I would of ordered the other Disc's.
Old Dec 17, 2020 | 11:53 AM
  #52
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
@AUM , I misunderstood your question, my apologies.
See if this post taken from the 7.3L PSD Tech Folder helps you out. If not, one of us can get the Ford Service Manual going.
https://www.ford-trucks.com/forums/1...l#post19040359
Old Dec 17, 2020 | 12:46 PM
  #53
AUM's Avatar
AUM
Awesome Sous, thanks, seemed to miss that in the tech folder.
Do both sides of headlight wiring need to be connected to the harness and relays? I´ve only got one power plug stemming from the harness I purchased on ebay.
Old Dec 17, 2020 | 01:13 PM
  #54
Sous's Avatar
Sous
FTE Emeritus
Not in my experience. The connection to the OEM harness to the relay harness on my truck was accomplished on the passenger side. The two relays were installed next to the washer fluid fill port and the driver side wire was run under the tool tray/radiator cover.
That said, be sure that the driver side OEM harness wires are secured and safely covered up.
Old Dec 17, 2020 | 08:36 PM
  #55
CousinCarl's Avatar
CousinCarl
I can verify this works connecting the driver side to the relay harness as well. I have my F350 and Excursion done this way.
Old Dec 17, 2020 | 08:41 PM
  #56
Sous's Avatar
Sous
FTE Emeritus
Thanks for the additional information. We can never have top much information or detail, especially when dealing with electrical wiring.
96f150
1997 - 2003 F150
Dec 4, 2008 09:08 AM
mino54
Electrical Systems/Wiring
Mar 20, 2006 04:57 PM
klatt_89
Jan 14, 2006 04:24 PM
thenewjohndeere
1978 - 1996 Big Bronco
Dec 15, 2005 05:52 PM
GasMonkey
Appearance & Dress-Up
Jan 18, 2005 10:10 PM
