Bilstein steering damper vs stock
Old 04-10-2020, 04:30 PM
kurthb's Avatar
kurthb
kurthb is offline
06 F250 towing 28' 5er, upgraded the shocks with Bilstein 4600. Wondering if I would gain anything upgrading the steering stabilizer with the Bilstein 5100? I had replaced it with a OEM equiv 2 years ago. (stock tires)
Old 04-10-2020, 05:55 PM
HRTKD's Avatar
HRTKD
HRTKD is offline
Boondocker
Received 7,153 Likes on 2,859 Posts
What are you trying to solve?
Old 04-10-2020, 07:35 PM
kurthb's Avatar
kurthb
kurthb is offline
When towing (all weights are within capacities inc payload) front/steering feels light, I want to tighten up it a bit, can't describe it other than that way.
F250 steering isn't exactly precision steering so I thought a better stabilizer would tame it down a bit.
Old 04-10-2020, 07:40 PM
HRTKD's Avatar
HRTKD
HRTKD is offline
Boondocker
Maybe too much pressure in the front tires?
If your trailer was a bumper pull, I would say that too much weight was removed from the front axle. But with a fifth wheel? I didn't think it worked that way, but maybe your hitch isn't setup quite right?
Maybe the steering/suspension components are worn out and need a refresh. A steering stabilizer may be a band-aid for worn components.
Old 04-10-2020, 07:57 PM
kurthb's Avatar
kurthb
kurthb is offline
5th wheel, hitch setup correctly, trailer completely level. Weights confirmed on CAT scale. Truck has only 37,000 miles on it.
Old 04-11-2020, 01:56 PM
whooboy's Avatar
whooboy
whooboy is offline
I don't know the year or size of your truck, but on my '15 F-350 crew-cab long-wheel-base single-rear-wheel truck, replacing the steering stabilizer with the Bilstein helped. What helped the most, was a rear stabilizer. My long-wheel-base truck did not come with one from the factory and when towing, the front end wanted to wander. The stabilizer bar really made a difference.
Old 04-12-2020, 12:48 PM
kurthb's Avatar
kurthb
kurthb is offline
2006 short bed supercab. Rear stabilizer? You mean rear sway bar? If so I added one a Hellwig one couple years ago.
I went ahead and ordered the Bilstein steering stabilizer, nothing but great reviews.
Old 04-15-2020, 11:57 AM
SuperDuty Wannabe's Avatar
SuperDuty Wannabe
SuperDuty Wannabe is offline
The Bilstein Stabilizer is, was a nice up-grade. Just a better Steering Feel. No different than replacing Ford O.E. Shocks with Aftermarket Shocks. Just rides better.
Old 04-17-2020, 05:56 AM
EDC8008's Avatar
EDC8008
EDC8008 is offline
If it gets "LIGHT" when put a load on the truck then it's unloading the front axle. Yes replacement of the damper will help. You can have the trailer level but you can still be removing weight off the front axle of the truck.
Have you weighed the axles both loaded and unloaded? Be sure that you have each axle on it's own plate. also brakes need to be off so the truck will settle. This will confirm whether the weight is coming off of the axle.
Have you measured height at the top of the fender arch to verify? If the height from the ground or the center of the axle to the top of the fender arch increases you are unloading the front axle.
Old 04-17-2020, 12:27 PM
kurthb's Avatar
kurthb
kurthb is offline
Camper weighs 8800# as loaded for a weekend. Pin weight is 1380#, weight added to front axle is 80#, weight added to rear axle 1300#. Rear squat 1.5", front squat, never noticed or measured.
Old 04-22-2020, 07:59 PM
lariatbob's Avatar
lariatbob
lariatbob is offline
You might also look and see if you can move the hitch forward (or more forward) of the rear axle to distribute the load more forward.
Amicus
09-11-2016 07:15 PM
Amicus
09-06-2016 02:05 PM
Rick Cargo
6.7L Power Stroke Diesel
55
08-22-2012 05:41 PM
mikewrt
1999 to 2016 Super Duty
06-08-2009 08:07 PM
mdwilli
30
04-21-2009 10:25 PM
Quick Reply: Bilstein steering damper vs stock
