Tuner / programmer question...
Old Mar 29, 2020 | 09:55 AM
afonda's Avatar
afonda
I am running the max energy.. have been for like 10 years... are there any updates ... should I consider a different type?
Old Mar 29, 2020 | 10:44 AM
SkySkiJason's Avatar
SkySkiJason
No idea what that is. But, almost anything is better than tunes from an OBD2 programmer.
Hydra with PHP tuning library is about $325 and if you are happy about what you have now - you will LOVE this.
Old Mar 29, 2020 | 01:09 PM
afonda's Avatar
afonda
Hypertech max energy programmer.
Old Mar 29, 2020 | 01:14 PM
afonda's Avatar
afonda
How do you install hydra?
Old Mar 29, 2020 | 04:35 PM
SkySkiJason
Wow. That is especially bad... lol.
https://www.hydrahelp.com/install.html
Old Mar 30, 2020 | 04:32 PM
afonda's Avatar
afonda
why? Just curious...
Old Mar 30, 2020 | 09:44 PM
SkySkiJason
100% throttle at 50% pedal is a stupid trick early tuners used to make people think their truck has ‘more power’.
Often they increase transmission line pressure and make hard shifts. Also annoying and harmful to boot.
High EGT’s are common too.
Old Mar 31, 2020 | 08:56 AM
afonda's Avatar
afonda
interesting feedback... I do think it shifts hard.. no pyro.. so not sure about the egt's..
Old Mar 31, 2020 | 04:46 PM
jstihl's Avatar
jstihl
I definitely agree with Sky ski, get a hydra oh, you won't regret it. It will open up a whole new world of possibilities for your truck. If you want something easier to install there are the edge products that plug directly into your OBD2 port
Old Apr 1, 2020 | 07:22 AM
afonda's Avatar
afonda
does the hydra allow you to adjust tire size?
Old Apr 1, 2020 | 08:17 AM
SkySkiJason
No. But that can be done with a pro scan tool like AE, Snap-on, etc. We go into ABS module to change tire size.
Old Apr 1, 2020 | 09:12 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Forscan does and we have a video and write up in the 7.3L PSD Tech Folder detailing how to accomplish this task.
Old Apr 1, 2020 | 07:53 PM
00t444e's Avatar
00t444e
Get egt and boost gauges before you put any tuning on a 7.3 or any other diesel, very important.
Old Apr 2, 2020 | 03:48 PM
afonda's Avatar
afonda
I do have a fuel pressure gauge and a boost gauge. I will look into getting a pillar pod to add the extra EGT gauge. Been wanting that anyway...
Old Apr 2, 2020 | 04:03 PM
Sous's Avatar
Sous
FTE Emeritus
An EGT gauge is the single most important gauge that can be installed on our truck.
The fuel pressure provides good to know information and may help identify an issue with the fuel system, but it is not essential. A boost gauge is fun to watch and also provides good to know information, but is not essential.
The EGT gauge provides critical information based on how your truck is running. I in no way shape or form would run a tuner device or chip in my PCM without an EGT gauge. As a matter of fact, several years ago I installed gauges in my truck with a few other fun things and ran it that way for about a month before installing the Hydra I had sitting on my work bench.
Although, my goals and aspirations of efficiency, reliability and longevity for my truck do not line up with some others, so do as you wish sir.
James Mckinney
6.4L Power Stroke Diesel
Apr 6, 2017 04:36 PM
corwin132
Apr 10, 2011 05:58 AM
tomfrey
Dec 24, 2008 12:55 PM
jfletcher72
Computer Chips & Tuners
Jan 12, 2007 02:21 PM
