Brake cable Trouble
Old Mar 22, 2020 | 10:33 PM
hentzrd's Avatar
hentzrd
Question Brake cable Trouble
I am new to this site at posting so I will do my best to ask this question. I am rebuilding a 1976 F100 short bed vin number F11YLA50173. I purchased the Frame and cab in Arizona and towed it to PA. In PA I have an old F150 short bed I purchased new in 1978 vin number F14BNCB0732. So I am using the old frame and cab from Arizona to recreate the Pa one. It sure comes with challenges!!! But it keeps me busy. The F100 had a V8 and I changed it to my 300 6. all went well and the drive train is all installed. However now I am facing some challenges after installing the cab. I ordered new emergency brake cables and installed but the front line from the pedal assembly to the rear Joint Cables comes up short.
I ordered the 1976 cable and it comes up about 2" short. It should work since I did not change anything as far a framework on the old frame or cab. So if someone can lead me out of this problem or suggest what I have wrong I would appreciate it.
I am also wondering what to do with the throttle cable since the old one was a mechanical through the firewall and the one I have is the 1978 spring Cable. Does anyone have experience with modifying an older cab to the new throttle?
Thanks
Randy
Old Mar 22, 2020 | 11:30 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by hentzrd
I am new to this site at posting so I will do my best to ask this question. I am rebuilding a 1976 F100 4WD short bed, VIN: F11YLA50173. I purchased the Frame and cab in Arizona and towed it to PA. In PA I have an old F150 4WD short bed I purchased new in 1978, VIN: F14BNCB0732. So I am using the old frame and cab from Arizona to recreate the Pa one. It sure comes with challenges!!! But it keeps me busy. The F100 had a V8 and I changed it to my 300 6. all went well and the drive train is all installed. However now I am facing some challenges after installing the cab.
You forgot to mention that both of these trucks are 4WD!
1976/79 F100/150 2WD/4WD Regular Cabs use the same rear cables, but the 4WD front cable is different than 2WD
Plus, 1976/77 use a different front cable than 1978/79, part time/full time drive also makes a difference.
Please, when asking questions, list all the pertinent info and be aware that only a few members can decode VIN's.
I happen to be one of them. F11 = F100 4WD Pickup // F14 = F150 4WD Pickup
So, what front cable did you order?
Old Mar 22, 2020 | 11:46 PM
hentzrd's Avatar
hentzrd
Brake cable Trouble
Thanks for the quick response. I will try to do better on my posts. I also put two problems on one post which I later read is not good either.
Have you ever heard of someone attempting to do what I am doing? I first purchased the front cable figuring it was the same as the 1978 and that one was short. So next I purchased the correct one for the 1976 but I am also coming up short. even though this cable is slightly longer. I have the complete manuals but I am not good at finding anything on them yet. Plus my CD drive went south on me.
Old Mar 23, 2020 | 12:06 AM
NumberDummy
1973/79 Ford 100/500 Series Truck Parts Catalog - Text, Section 23.2 page 1: Parking Brake Application Chart // Parts List #39B - 1976/79 F100/150 Regular Cab 4WD
D6TZ-2853-B .. Front Parking Brake Cable - 89 5/16" long = 1976/77 F100/150 4WD with Part Time Drive.
D6TZ-2853-C .. Front Parking Brake Cable - 95 5/16" long = 1976/77 F100/150 4WD with Full Time Drive.
D8TZ-2853-C .. Front Parking Brake Cable - 107 1/4" long = 1978/79 F150 4WD with 133" wheelbase (8' bed).
D8TZ-2853-D .. Front Parking Brake Cable - 90 1/2" long = 1978/79 F150 4WD with 116" wheelbase (6 1/2' bed).
Old Mar 26, 2020 | 06:13 PM
hentzrd's Avatar
hentzrd
I just wanted to let you know I appreciate your knowledge and help. I got the E brake hoked up. I am now working on the gas pedal. Is there a grommet where the pedal goes through the fire wall? I cannot find any on the manuals I have. And I also need the bracket to mount the spring cable. Any drawing or help is what a need.
Thanks
Randy.
Old Mar 26, 2020 | 07:58 PM
John89's Avatar
John89
Try these.
A JY may be your best option. There is another thread with a similar throttle cable issue.
Do you have the bracket that mounts to the intake?
The lever that comes up from the pedal through the firewall needs to have a fork at the tip for the cable to attach to.
Shadows were tough in the first few pictures.
Bracket is just under brake booster hose.
Different view. One stud on top.
Two studs on bottom. Bracket is shaped kinda like a backwards "F"
Fork at tip of throttle rod.
Throttle rod is just behind (right of) spark plug wire.
Old Mar 26, 2020 | 08:14 PM
hentzrd's Avatar
hentzrd
Smile Brake cable Trouble
You just answered my question. I'm sure I have the two parts. It has been so long I was not sure how it mounted. I have both brackets. I just did not know which one and how it mounted.
Thanks for the picture!!! You saved me a drive to a guys place who has many of these trucks.I use them when I get stuck.
Randy
Old Mar 26, 2020 | 08:17 PM
hentzrd's Avatar
hentzrd
Looks like there is a boot for where the linkage comes through the firewall. i
to check if I have one. I cant find it on LMC or Carpenter.
Old Mar 26, 2020 | 08:23 PM
John89's Avatar
John89
I'll check tomorrow when I have some daylight.
Also here is where the bracket by valve cover mounts.
Bracket mounts in the two holes on top of intake manifold.
bracket just to the right of carb.
Old Mar 26, 2020 | 09:04 PM
hentzrd's Avatar
hentzrd
OK thanks!!! I have everything I need except the boot if there is one. I had to laugh when I saw the picture because I had the bracket all the time and just could not remember where it went. I'm old LOL
Old Mar 26, 2020 | 09:08 PM
John89's Avatar
John89
If you have spare parts the OP of this thread might be able to use them.
https://www.ford-trucks.com/forums/1...-300-swap.html
reluctantfiver
Nov 27, 2016 10:12 PM
castone001
Aug 21, 2011 09:31 PM
florida boy
Apr 7, 2011 10:33 PM
jfarcas
Apr 23, 2007 08:32 AM
Bouts21
Jan 6, 2005 01:30 PM
