Engine Rebuild Issue
Old Apr 15, 2020 | 11:24 PM
  #46
TooManyToys.'s Avatar
TooManyToys.
I haven't taken the red pill yet; I need to see repeat issues.
But the torque wrench vs angular tightening, that red pill went down long ago.
Old Apr 16, 2020 | 12:40 AM
  #47
Fuzzpuss's Avatar
Fuzzpuss
When you pull heads off an active motor coolant and oil go everywhere. It's all about the cleanup afterward. You do as much as you can beforehand.
Before I put my studs in, I'll be talking to ARP.
The term scattering typically means inconsistent tension between all the fasteners. I've never heard it used for the release of a fastener twist. Unless they meant the release of the twist was causing scattering.
The release of the twisting does reduce tension, it's backing off the threads and it's well known. Ideally, you want to minimize twisting of the fastener, which is what I thought this ARP lube was supposed to do, better than any other. I think in Mac's thread I asked or stated the studs should be marked as well as the nuts so you can see if there is any twisting of either afterward. That's actually common practice on critically tensioned components. In my first professional job, I used to work with guys that built the hatches on the Space Shuttles - that's critical fastening.
One thing I was planning on talking to ARP about which relates to this is to not lube the threads in the block for higher frictional loading within the threads, and the possibility of using low or medium grade Locktite in the block threads to "plant" the studs. You don't know if the release of the twist is occurring at the block or at the nut.
Some engineers state 40% of the torque is used by the thread friction, and 50% used in the nut to washer friction. This is why I've always been amazed that ARP uses a torque value, not even putting into the equation of torque wrench inaccuracy. This is why angular tensioning was put into practice; you know the thread pitch, so with an angular rotation it's easy to determine the degree of stretch (clamping force) you have achieved by rotating 360º or whatever. It's doesn't matter the frictional forces or the accuracy of the torque wrench.
Can you provide links to where this discussion has come up before in your research?
I would be interested to know what ARP says about your concerns. Also if they have an angular tensioning procedure in lieu of torque. Wouldn't that be nice?
I never understood the need to lube the threads in the block. And what's the rationale behind backing the stud out an eighth of an inch? Is it simply a difference in expansion coefficients between cast iron and steel?
Old Apr 16, 2020 | 05:29 AM
  #48
TooManyToys.
The problem with the studs bottoming in the block is if the studs turn you will start to also be applying a force pushing the studs upward, not just the tension force across the body of the stud. Now you can exceed the threads capability with the potential to strip out the block threads.
Thread engagement theory is (to me) interesting. In the typical hard metal materials, you only stress in some cases the first four threads. It can vary depending on the stiffness of the metal, there is always distortion. With more compliant metals, like our rocker boxes or manifold, more threads will engage due to the distortion.
It depends on how deep the rabbit hole you want to go. Fastenal has some good data.
Also briefly - https://fieldfastener.com/2018/03/13...ad-engagement/
But there also effects with temperature .... deep rabbit hole......
You can develop very high yield point studs and nuts, the weaker link, but the block threads are what they are. The 6.0 blocks so far haven’t been an issue, but when ARP first came out with studs for the 6.4L, they had to back off the torque values as the blocks were starting to crack by the lifter bores due to the stress.
People usually don’t think about the block upwelling around the head bolt locations and stress within the block. And what they use to clean the block threads with. The International service manual says to use a tap, but most consumer taps have a poor grade thread. It should be a thread chasing tool, or a modified bolt to not tear out more metal.
ASTM has the best studies and standards when it comes to strength. You know, the bridge and pressure vessel/piping guys.
Old Apr 16, 2020 | 10:36 AM
  #49
Fuzzpuss's Avatar
Fuzzpuss
The more I learn, the less I know. Thanks Jack. You're a good source for rabbit holes.
Old Apr 16, 2020 | 10:46 AM
  #50
TooManyToys.
Originally Posted by Fuzzpuss
The more I learn, the less I know. ........
Welcome to my life.
Got one in the back yard. She keeps checking it every couple of days. We’re waiting ......
Old Apr 21, 2020 | 11:55 AM
  #51
TooManyToys.
Crickets .....?????
Old Apr 22, 2020 | 12:11 AM
  #52
Fuzzpuss's Avatar
Fuzzpuss
Must be busy working. Some people still have jobs ya know...
Old Apr 30, 2020 | 11:37 PM
  #53
DillF250's Avatar
DillF250
https://www.google.com/url?sa=t&rct=...L3TFbyGjqoO3XO
Old May 1, 2020 | 12:14 AM
  #54
TooManyToys.
Thanks. I saw that when you were gone for a while. The LS1 guys see that too with the aluminum heads.
Pkupman82
19
Mar 24, 2020 09:28 PM
Ironpants
36
Apr 26, 2014 08:44 PM
'59 F100
Oct 4, 2009 06:48 PM
Cruiseomatic
Dec 24, 2004 12:21 AM
bearfoot_25
Jun 26, 2003 07:17 PM
