SEIC (High Idle) 2020 Model Install
Old Feb 3, 2022 | 07:56 AM
  #121
Great Danes's Avatar
Great Danes
Originally Posted by robert sloane
not sure if the bd kit will work that way,
shutting it off at an uppfitter.
right now if you defeat the high idle on the BD kit( by pressing brake or any of the other safeties), you have to rotate the **** to the OFF position then rotate to the desired idle rpm
if you kill it with the uppfitter you might have to do the OFF then back ON on the bd kit ****????
I installed the BD kit about a year ago and it does in fact work via the upfitter. I clipped the yellow wire and wired it to upfitter #1 (sorry no pics). Once all was connected, I turned on the upfitter and then adjusted the pot **** to my desired RPM. From that point on, I just use the upfitter to turn the idle on and off as desired. I mounted the potentiometer in the upper left of the lower glove box. If I want higher or lower RPM, I simply turn the pot accordingly, but I never have to cycle it off or anything like that.
Old Feb 3, 2022 | 11:22 AM
  #122
B-ManFX4's Avatar
B-ManFX4
Originally Posted by WhiskyThrottle
I'm planning to use this configuration. My only concern is that I don't see a fuse. After looking at it more, I'm not certain if it needs one as all the circuits are likely fused already. Has anyone confirmed that?
The upfitter source is fused. The outputs from the PCM are fused internally.
Old Feb 3, 2022 | 03:32 PM
  #123
Reb2973's Avatar
Reb2973
Ok thanks, that’s what I was hoping for. So it would be the yellow wire on the plug side of bd kit? Just clip it there and attach that wire to upfitter? I also planned on putting the **** in the upper glove box if I can. Haven’t dug around in there yet. Kit just arrived
Old Feb 3, 2022 | 04:57 PM
  #124
Reb2973's Avatar
Reb2973
It’s fits good in there. Just finished. Already hooked upfitter to pass through wire. Now just have to plug it in and connect the yellow wire but I’m running out of daylight.
Old Feb 3, 2022 | 05:47 PM
  #125
powerboatr's Avatar
powerboatr
hey thats where i put mine awhile ago
GOOD job
i like how its not in plain sight and and easy to get to
Old Feb 3, 2022 | 06:02 PM
  #126
Reb2973's Avatar
Reb2973
Yes, plus not drilling into my dashboard on new truck. Here I thought I found a creative new spot for it and you beat me to it. Ha
Old Feb 4, 2022 | 07:29 AM
  #127
Great Danes
I decided the little space in the lower glove box was more suitable. Placed it beside my strobe pattern change button.
cpobst
Nov 20, 2020 07:05 AM
screwy
Sep 7, 2016 08:13 AM
Brandon D
6.7L Power Stroke Diesel
Oct 13, 2014 07:12 PM
Midnight Ride
Jun 15, 2013 06:05 AM
erniesshop
Aug 29, 2010 09:04 AM
