P0741 code
Old Mar 18, 2020 | 09:25 PM
96XLTczny's Avatar
96XLTczny
P0741 code
Finally took my 96 PSD into a shop today for diagnostic scan. Code P0741 causing a P1728 slip fault. And that 741 code won't clear. The shop is guessing the PCM is at fault now(?)
Because its a Montana truck that's been driven in WA, ID, MT, UT & WY extensively I'd think corrosion at PCM connector could be a cause perhaps(?)
Wasn't getting any response over at the transmission forum here on FTE:
https://www.ford-trucks.com/forums/1617085-96-97-4x4-e4ods.html
P0741 code
https://www.troublecodes.net/pcodes/p0741/
Old Mar 19, 2020 | 11:24 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It could be the PCM, the Torque Converter Clutch solenoid, or most likely, a damaged wire between those two.
Old Mar 19, 2020 | 02:11 PM
96XLTczny's Avatar
96XLTczny
The shop found an add-on module with harness to the PCM. They bypassed this & the P0741 code cleared.
They had tried another solenoid pack to make sure it wasn't a harness problem. Now the TCC is working.
But, L/R clutch pack still is slipping at times so I'm having a complete O/H & upgrades to this E4OD.
When I get my truck back I'll get some pics of this mystery module & harness.
Old Mar 26, 2020 | 04:20 PM
96XLTczny's Avatar
96XLTczny
BD-power pressureloc fail
Apparently some PO had added this BD-Power pressureloc #1060380 to the trans harness. I'm the 4th owner of this 1996 F250 so I don't have the complete history of what was done in yrs past. There's an add-on harness from this unit to trans harness for control of lockup I guess.
BUT, it wasn't working at all due to connection(s) on board heating up & dripping solder, thus causing shorts. Knew something was wrong when I heard rattles shaking the control box...
I think this failed unit is what burned up the TC friction disk as it acted like a compression brake in 2 & 1 while coming to a stop. I could feel a shudder that's not there now.
Stripped everything BD-powerloc out of my truck after I got home.
E4OD trans had some burnt frictions & steels plus L/R sprag had grenaded. Upgrades were done like forward planetary, etc.Trans case, center support & alum pistons were all fine according to shop mgr.
IF I had had the space to do it, would've overhauled it myself. Shifts great, clean & quick but not too hard. Can definitely feel 4th gr lockup now.
File Type: pdf
milehi_350
13
Jun 17, 2015 09:37 PM
Restlesswildman
Jul 2, 2014 06:08 PM
97 HD
Nov 11, 2007 07:37 AM
RDC F250 7.3
Oct 8, 2007 10:00 AM
