Repetitive 0603 code`
Old Jun 28, 2014 | 01:36 PM
Restlesswildman's Avatar
Restlesswildman
I keep getting a repetitive 0603 for KAM memory failure.
What is going on with that? Am I in for a PCM/ECU failure or am I going to go on a wiring fishing trip!
Old Jun 28, 2014 | 03:08 PM
Edogsf350's Avatar
Edogsf350
subscribine as i also have this code
Old Jun 28, 2014 | 05:02 PM
78fordman's Avatar
78fordman
Do you have any sort of programmer?
Sent from my leash using IB AutoGroup
Old Jun 28, 2014 | 05:06 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Take a look at the PCM connectors and check for corrosion.
Josh
Old Jun 28, 2014 | 06:02 PM
cheezit's Avatar
cheezit
Pcm is resetting, vref short, bad injector coil or you have really crappy batteries
Old Jun 30, 2014 | 12:00 AM
Restlesswildman
It tossed a # 5 injector code a week ago. Cleared it and haven't seen it since. Truck is driving fine.
Old Jul 1, 2014 | 06:27 PM
Restlesswildman
Well today I got a camshaft position code today! I am wondering if I have a wiring issue...
Old Jul 1, 2014 | 07:07 PM
cheezit's Avatar
cheezit
Most cmp codes are set when attempting to start.
Old Jul 1, 2014 | 09:15 PM
Restlesswildman
So is it a sensor error? Or am I missing something else going on?
In your earlier post you mentioned a bad injector coil would set the 0603 code. Why would that be?
What is Vref? Reference Voltage?
Old Jul 2, 2014 | 01:11 AM
Yahiko's Avatar
Yahiko
All the sensors need a base voltage so they can
operate. Vref is that power. It is a regulated power
feed to sensory that use variable resistance and the
PCM looks at what it gets back from the sensor and
that is compared to the Vref. One thing that drove Miles
up the tree was the short in the EBP. Vref was shorting out
and making him look at the accelerator circuit.
Am I making any sense? I think I can explain it different if you need me to.
Sean
EDIT : Found you some goodies.
Old Jul 2, 2014 | 05:21 PM
Restlesswildman
Good thing I have a week off of work. I will spend it under the hood trouble shooting what is in the PDF's.
Thanks for spoon feeding me the info Yahiko!
Thanks Cheezit for the starting point!
Old Jul 2, 2014 | 06:08 PM
cheezit's Avatar
cheezit
A p0603 is a kam code. Keep alive memory.
You wont find it in any book but a faulty injector coil can cause your pcm to reset, when the coil shorts out it will shut the engine down and set the p0603.
hotrodfeguy
Aug 8, 2018 07:20 AM
wildstang
Aug 28, 2013 09:52 PM
acf6
Dec 22, 2011 03:38 PM
stroke-of-luck00
Oct 22, 2007 07:34 PM
RDC F250 7.3
Oct 8, 2007 10:00 AM
