No. Dual tanks were in the crew cab. I had a 76 f150 4wd swb. Had done extensive pondering on the prospect of dual tanks. There simply is not enough room for the forward tank unless it is in-cab.
Dual fuel tanks were available on most 1973/79 F100/350's.
I don't disagree but he is asking about short beds. I personally have never saw a short bed with dual tanks, style side or step side. Not say'n there isn't, just I never have noticed one out there.
Dual fuel tanks were not limited to Crew Cabs. You could get F100/350 Regular & Super Cabs with dual fuel tanks.
Some trucks had an in-cab tank (thru 1977) and aft axle tank, some had a mid-ship and aft axle tanks.
Good luck. No dual tanks for short bed regular cab unless, by chance, one was in-cab. Long beds, did not matter the cab configuration, were available with dual tanks. The only feasible way to install dual tanks in regular cab SWB would be to have an in-cab tank or, possibly, saddle tank like a GM.
Yes you could get dual tanks on a shortbed. Here's pics of one. I'm guessing if you wanted dual tanks on a 8' flareside, one of them would be behind the seat as well https://inventory.gasmonkeygarage.co...d-f150-4x4-swb
I find it's just about impossible to replace either of the dual tanks right now w/o a 1-2 month wait.
I know you were asking whether they came oem on a specific model. Had to chime in with my two cents worth.
