77 F-250 Custom engine
Old Aug 24, 2021 | 08:52 PM
CustomLenny's Avatar
CustomLenny
I'm new to the site and need desperate help. I have a 1977 F-250 Custom im trying to fix up. There is a chance at some point there was an engine overhaul or engine swap. By vin number it should have a 351M, but I have also been told it could be a 400 or 460. I've found these cast numbers if someone can help me figure it out. D7TE-9C485-DHA AND D5AB-8401-AB both found on the side of the same side of the engine.
Old Aug 24, 2021 | 10:08 PM
440 sixpack's Avatar
440 sixpack
Unfortunately I believe it's a 335 series engine and that's a bummer. if it's a 2v carb it's not a 460 all 460's were 4v and all 351's and 400's were 2v. obviously someone could put a 4v on a 335 series though.
There are other ways to tell but a 2v is a dead give away for a simple identification.
Old Aug 24, 2021 | 11:30 PM
85e150's Avatar
85e150
429/460 = 7 bolts to hold on the valve cover
351m/400 = 8 bolts to hold on the valve cover
Those casting numbers are close to those for 351M/400s,, but not an exact match to anything I can find.
It's probably the original 351M.
Old Aug 25, 2021 | 01:29 AM
Christmas's Avatar
Christmas
The only way to know for sure is to measure the stroke.
Old Aug 26, 2021 | 07:38 PM
CustomLenny
It has a 2v carburetor. any other way to narrow it down.
Old Aug 26, 2021 | 07:49 PM
85e150's Avatar
85e150
If it has 8 valve cover bolts, it's probably the OEM 351M.
Externally, the 351M and 400 are identical. Crank and pistons are the only difference. It's difficult to check the stroke via the wire down the spark plug hole method, but if you are careful, you may be able to get a measurement.
You say you are trying to fix it up. OK, does it run?
If it runs, does it run good? If yes, tune it up, fresh oil and drive it.
If it doesn't run, try to figure out what's wrong and then decide if you're going to rebuild it. If you have to rebuild it, make it a 400.
More power is almost always a good thing, but even with the limited power of the 351M, BILLIONS of miles were racked up by 351M powered vehicles.
mustang81
Jan 26, 2013 05:29 PM
rex-man
13
Mar 24, 2009 04:37 AM
llehmn
May 14, 2008 08:52 PM
thunderman
May 4, 2004 07:46 PM
Binder Guy
Apr 19, 2004 06:36 PM
