1979 ford 302
Old Mar 8, 2020 | 02:57 PM
Naterb43's Avatar
Naterb43
1979 ford 302
So Im looking for some advice on what kind of long block to purchase to replace the original 302 in my 79 f100 custom with manual tranny. Not really looking for hp,but looking more for “everything bolts up as should”. I’m not a mechanic by trade but a machinist,so I understand mechanics to a degree. Any advice on what or who to stay away from or even what years will fit this truck and everything still bolts up as should would be great an highly appreciated.
Tia
Old Mar 8, 2020 | 03:04 PM
slashfan7964's Avatar
slashfan7964
1968 to 2001 will physically bolt in. 1986 they started fuel injection, but it is easily removable and a matter of swapping a carbureted intake onto it, and sometimes a distributor.
Now would be a good time to upgrade to a 351W as it is a bit more powerful and bolts in exactly the same as a 302 would.
Old Mar 8, 2020 | 03:48 PM
Naterb43's Avatar
Naterb43
Awesome info. I assume the original isn’t worth rebuilding .?i really don’t care for the two piece rear main seal.
Will the 351 bolt in for those same years?
Old Mar 8, 2020 | 03:52 PM
slashfan7964
Any 351W will fit.
Wether or not its worth rebuilding is your call. You won't find one with a 1 piece rear main until the fuel injected engines.
Old Mar 8, 2020 | 04:20 PM
Naterb43's Avatar
Naterb43
Originally Posted by slashfan7964
Any 351W will fit.
ok, guess I need to do some homework . Ty so much for the info.
Old Mar 8, 2020 | 06:42 PM
matthewq4b's Avatar
matthewq4b
The 351W went to a one-piece rear main in 83, as did most everything else.
Old Mar 8, 2020 | 06:50 PM
Naterb43's Avatar
Naterb43
thanks for the info. I guess my issue with the 351 is finding all the power steering stuff alternator stuff etc. unless the 302 stuff is a direct bolt on.
Old Mar 8, 2020 | 06:56 PM
slashfan7964
Some of it works and some of it doesn't. your best bet is to find a 351 with all of it already on it, I think some of the brackets are longer due to the taller deck height.
Old Mar 8, 2020 | 10:24 PM
matthewq4b's Avatar
matthewq4b
Depends on what set up you use. If it is the non auto-tension serpentine system it fits both. Low mount Alts fit both. Other then the fore mentioned serpentine system none of the PS systems will fit both.
frankensteined_67
Aug 29, 2015 09:05 PM
Jim Donohue
Engine Swaps
Nov 13, 2008 08:44 PM
Scifi266
15
Nov 27, 2007 01:49 PM
Mudder
Oct 3, 2005 07:57 PM
Jim Larson
Dec 20, 2002 04:46 PM
