Help please
Old Nov 24, 2007 | 12:22 AM
Scifi266's Avatar
Scifi266
Help please
Hey guys, I've been looking for the motor perches for a 302/351w to fit in my 66. My local pick a part has no trucks with 302's in them and I was wondering if you guys had any spare. Pm me with any info. Thanks a lot guys.
Old Nov 24, 2007 | 04:24 AM
jowilker's Avatar
jowilker
What year trucks are you looking for them in? It was about 69 before a 302 was used in a pickup. You can look up to 79 for fit.
John
Old Nov 24, 2007 | 06:30 PM
bliss1's Avatar
bliss1
the stock perches will work for a 302. you will have to move the perches back on the frame, but the holes are already there. i used the 69 302 engine mounts with this.
Old Nov 26, 2007 | 01:10 AM
Scifi266's Avatar
Scifi266
I was looking from 72 to 79 but i just can't find any with a 302
Old Nov 26, 2007 | 08:20 AM
1965F100's Avatar
1965F100
The 300/302/351/3.8 all have the same perches don't they?
Old Nov 26, 2007 | 09:05 AM
jowilker's Avatar
jowilker
Don't know what a 3.8 is, but the 352/360/390 and I-6 use the same perches the 302 used a different set. There were no Ws installed until into the 80s and doesn't apply.
Scifi266, Don't know why you cant find any, I can only suggest that you keep looking. Don't give up they are out there. Concentrate on the dent sides.
John
Old Nov 26, 2007 | 09:07 AM
garbz2's Avatar
garbz2
No
240,300 and 352,360,390 perches are the same in either the forward or rear bolt position.
302 and 351M/400M perches are the same, The modifieds use the cleveland mount location and pattern. Smae as a windsor.
Some have used the FE perches with small block isolators, but i dont see it being located the same as the FE The motor will be a little too far forward or rear ward using these.
Garbz
Old Nov 26, 2007 | 12:14 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by garbz2
No
302 and 351M/400M perches are the same, The modifieds use the cleveland mount location and pattern. Same as a windsor.
Garbz
I know you know these trucks very well, but your reference to "cleveland" might be misleading to some ppl. No 351C's were installed in F Series trucks. Only the 351M/400's were used...beginning in model year 1977.
Old Nov 26, 2007 | 01:11 PM
bliss1's Avatar
bliss1
i dont want to step on toes, but just because there diffrent parts for diffrent engines and trucks dont mean it wont work. you throw all the part numbers and specs and they dont mean a whole lot. ive found your info to be helpfull numberdummy but some times you need to step outside the box. if i went by every part number and spec i would still be chasing my tail.
Old Nov 26, 2007 | 01:29 PM
NumberDummy
I didn't say a 351C wouldn't work in a F Series truck. I said it wasn't original to a F Series truck.
Just remember something...not everyone that frequents these forums knows what a Cleveland engine is. Or a person might recognize the potential of a 351C, but not realize 351C's weren't installed in F Series trucks.
100's of ppl read these posts. I'd hate to see someone looking for a 351C engine in an F Series truck. I'd hate to read of someone who thought a 351M (or 400) was a 351C, and then installed it....the engines look identical.
The 351M engines are dog meat, so are the 75/82 400's. The heads are prone to cracking, the engines themselves are a smogged up POS.
Old Nov 26, 2007 | 01:42 PM
bliss1's Avatar
bliss1
i was reading a couple of post at the same time numberdummy sorry i got you mixed up with another user. it was someone else throwing specs out. but sense i have you here will the 69 302 perches fit in the 65-66 f100.
Old Nov 26, 2007 | 03:07 PM
NumberDummy
I've heard they will. Garbz2 will know for sure.
Old Nov 26, 2007 | 03:20 PM
jowilker's Avatar
jowilker
Yes they will bolt up.
John
Old Nov 26, 2007 | 03:34 PM
garbz2's Avatar
garbz2
Yes they will fit.. I use the cleveland refrence as the modifieds retained the clevelands engine mounting points. and they are the same as a small bolck windsor, Hence one can use a 302/351M/400M mount to mount a 351C. but not a 240/300/352/360/390 perch, But people on here will swear they used the 300 perch to mount a windsor? go figgure some times. I have always hunted the correct perch as it kept everything where it is supposed to be.
No 351Cs were put in trucks here i agree 100 percent, Aussies dont count. I don't pay much mind to part numbers either unless i am doing a points resto...Just use what in past experience has worked.
Sort of like a guy looking at supposedly NOS hubcaps on epay and noting the redlead primer that ford put in there aint there...Argent silver outside and redlead inside, at least in the hundred or so i have handled....So they aint NOS just nice restored ones....well over 275 last time i looked... F250 61 to 65 bottle cap innies....But being pawned off as NOS...whats the old saying...Buyer Beware....
Garbz
Old Nov 27, 2007 | 10:30 AM
RaleighDad66's Avatar
RaleighDad66
I would also offer that when setting the 302 that you keep in mind the fore/aft placement. The PO placed mine about 1 inch too far aft and it creates close quarters at the back of the head needlessly. With all that room, either put in a big block or slide that 5.0 off the firewall
