Replacement Engine for 78 Ford Pickup
Old Nov 12, 2008 | 11:45 AM
Jim Donohue's Avatar
Jim Donohue
I have a '78 Ford Pickup truck and need a new engine. The engine I pulled out is a 302. I have found a 302 for sale from a 94-95 mustang but the seller says it will only fit fords back to '79. Can anyone tell me if something changed between 78 and 79 and if I need to be checking anything specific while trying to find an affordable new 302 engine?
Thanks
Old Nov 13, 2008 | 07:55 AM
Conanski's Avatar
Conanski
The external dimensions and bolt locatons on the 302 block never changed, so there's no reason you can't put a newer 302 in there if you indeed have a 302 in your truck.
Old Nov 13, 2008 | 11:04 AM
loudfords's Avatar
loudfords
The seller is probably thinking Mustangs back to 79... It will fit fine and run well in your truck, you would just need to make sure to use an 82 up 302 flexplate if you have an automatic tranny.
Old Nov 13, 2008 | 08:44 PM
Ryan99's Avatar
Ryan99
Also make sure you use a newer balancer. 63-80 windsors were balanced with 28oz, and 81 up were 50 oz. The mustang ho motors use the 351w firing order.
denise
Dec 9, 2023 10:06 AM
78f250lj
WTB - Parts & other
Apr 18, 2010 07:41 PM
78f250lj
Engine Swaps
Oct 28, 2008 11:35 AM
79 posi
Mar 14, 2005 06:47 PM
jpb222
Feb 26, 2003 02:05 PM
