Rear main seal replacement
Old Mar 1, 2020 | 11:02 PM
rd65's Avatar
rd65
Anyone have experience with replacing rear main seal in a 1980 F350 DRW 2WD 400 C6 w/ stock exhaust? I looked under it tonight and I am not sure I can get the oil pan far enough forward to get to main cap/seal.
Old Mar 1, 2020 | 11:23 PM
kr98664's Avatar
kr98664
As best I can determine, Ford did NOT recommend the in-vehicle process on the large-block V8 in a pickup. The factory manual doesn't specifically say you can't, but it looks that way when reading between the lines.
Gory details here:
https://www.ford-trucks.com/forums/1...on-pulled.html
My experience with the 351W here, which has better access due to the smaller dimensions:
https://www.ford-trucks.com/forums/1...y-84-351w.html
Not exactly fun, but it was doable.
Old Mar 2, 2020 | 08:00 AM
ctubutis's Avatar
ctubutis
https://www.ford-trucks.com/forums/1...-pulled-4.html
Old Mar 2, 2020 | 10:43 AM
BigBlue2's Avatar
BigBlue2
My 6.9l diesel had a rear main leak. I tried the blue devil rear main sealer additive and it stopped the leak. It also stopped leaks around the pan gasket. It's only been about 3000 miles since I tried it, but still working good. Worth a try if you need to buy time for the money. Company claims it's a permanent fix with one application. The price was cheap. Before everyone piles on about snake oil...yes not as good perhaps as replacing the seal. I'm very pleased with the results so far.
tomde2
Dec 14, 2009 11:23 AM
Kindtkid
Aug 13, 2009 03:07 PM
kurtzdiesel
16
Nov 8, 2007 01:43 PM
