Bad sensor?
Old Feb 20, 2020 | 11:09 PM
Bogdeep's Avatar
Bogdeep
Question Bad sensor?
today my truck started surging at idle. i figured it was just warming up but when i got onto the road it seemed to be losing power up hills and bucking, the rpms at idle were randomly going from 950 to 500 and also my mpgs are down alot. bad icp? the truck does have a ts-6 chip and the fuel filter might not be to new but it ran perfect yesterday.
Old Feb 21, 2020 | 06:31 AM
Listor's Avatar
Listor
unplug icp and see if it changes anything
Old Feb 21, 2020 | 09:55 AM
Wes444's Avatar
Wes444
As mentioned unplug the ICP. And see how it does.
If that doesn't work unplug the fuel bowl heater and replace fuse #30 under the dash even if it looks good.
Old Feb 21, 2020 | 10:37 PM
RA101725's Avatar
RA101725
Banned
Got oil in it?
Old Feb 24, 2020 | 12:57 PM
Bogdeep's Avatar
Bogdeep
i replaced icp it was covered in oil it seemed to help but still has the same issues like stalling at stops and running terrible in reverse and surging before dying.
Old Feb 24, 2020 | 02:11 PM
Wes444's Avatar
Wes444
Did you unplig the fuel bowl heater?
Check the tinman nut on the IPR?
Old Feb 24, 2020 | 05:36 PM
RA101725's Avatar
RA101725
Banned
Unusual amount of smoke out of the exhaust of a certain color?
Old Feb 25, 2020 | 01:47 PM
AubieTN's Avatar
AubieTN
Before throwing parts at it pull codes if possible then remove the chip from the PCM and see if that helps.
Old Feb 25, 2020 | 02:06 PM
RA101725's Avatar
RA101725
Banned
Good idea. Drop the negatives off the batteries after pulling codes also and zero everything out.
EMC V10 X
Oct 7, 2019 02:50 PM
SHAWN056.0
Oct 4, 2013 08:09 AM
lakewood
Sep 10, 2011 07:13 PM
HKusp
Apr 22, 2010 11:15 AM
61 uni
19
May 21, 2008 02:05 PM
