ICP Sensor?
Old Oct 7, 2019 | 01:11 PM
EMC V10 X's Avatar
EMC V10 X
ICP Sensor?
I have been having and intermittent surge, but only at idle, which now has grown to a lack of throttle response at idle. After the initial checking fuel filter etc and normal check, it continued. After TONS of research, I think I have found my culprit. When the truck is acting poorly, The Scangauge Value is about 900-950 it tdle. When running well, it sits in the 600s. After reading quite a bit, I tapped on the sensor while it was acting up and Immediately it cleared up. Is there a way to clean the sensor? or should it just be replaced?
Old Oct 7, 2019 | 02:50 PM
TooManyToys.'s Avatar
TooManyToys.
Replaced with one from Ford.
Jmoen7
Aug 25, 2015 09:47 PM
chicagodragon
Jul 12, 2010 07:57 PM
jboard
Apr 7, 2007 10:21 PM
