Lope at idle
Old May 18, 2008 | 06:07 PM
61 uni's Avatar
61 uni
Lope at idle
My truck sometimes has a lope at idle. You can't hear it in the moter, but the truck will rock side to side very slightly like it has a big cam in it. Anyone ever notice this in their truck?
Old May 18, 2008 | 09:08 PM
WALJON's Avatar
WALJON
I get that from bad oil diesel engine oil defoamer seems to cure it
Old May 19, 2008 | 09:48 PM
61 uni's Avatar
61 uni
Anyone else?
Old May 19, 2008 | 09:56 PM
c00nhunterjoe's Avatar
c00nhunterjoe
if you have a chip or icp mods it can lope occasionaly,
most 7.3's have a semi-chopped idle...ie not purring.
if it enough to actualy shake the truck side to side it may be the icp going bad, next time it does it unplug the icp sensor while it is loping, if it smooths right out then you need a new icp sensor. dont forget to check the 3 pin pigtail for corrosion too.
Old May 19, 2008 | 10:37 PM
PAVEMENTMAN's Avatar
PAVEMENTMAN
Mine Has Been Doing That But Only When Engine Is Warm. Not Sure What It Is. How Hard Is It To Change The Icp Sensor.
Old May 20, 2008 | 09:16 PM
brown 4x4's Avatar
brown 4x4
Mine does it too sometimes when warm. Seems the worst when pulling in after a long drive. I previously had a miss at idle that you could feel in the cab and hear in the exhaust. It's much better now after a set of injectors but I still get the lope.
I know they're not all the way mine is anyway. I drove a 95 PSD the other day and immediately I noticed the idle. It was as smooth as a newer one. Kinda made me mad as my truck looks and drives brand new compared to this beat up one. Mine (which is stock) would run circles around it though as far as power.
Old May 20, 2008 | 09:22 PM
PAVEMENTMAN
I am not sure what it could be. maybe someone on here will help us out.
Old May 21, 2008 | 05:48 AM
WALJON's Avatar
WALJON
There can be a number of problems there start with simple things how old is your oil? what grade are you using? these trucks are very oil sensitive
Try what coon has suggested with the ICP
foamy oil will do this as well especially after a long run sounds crazy but it is true
Old May 21, 2008 | 07:09 AM
MADVAN's Avatar
MADVAN
Will also come from a out of range TRS.
Check and clean connection first.
TRS= Trans Range Sensor. Drivers side of trans.
Bill
Old May 21, 2008 | 07:31 AM
93f1505.0L's Avatar
93f1505.0L
My truck does it and I replaced the ICP sensor (it was leaking too) and had no difference. Does it more after a long pull too. I herd the Trans Range Sensor can cuase it too and I replaced that too. ( I was having trans problem so I figured it was worth a shot). I still havent fixed it but the part that bothers me the most is the shake. I get people all the time that say there sounds like there is something wrong with your truck and i just say I put a cam in it and they just agree like thats a good mod for a diesel.
I do have a 14.7K resitor on the ICP but the truck did it before and after that. I dont think its the superchip becuase it does it when I program it to stock too.
Good luck on fixing it just thought I would share what I replaced to try to fix it.
Old May 21, 2008 | 07:44 AM
MADVAN's Avatar
MADVAN
Motor gets to opt temp?
EOT compares?
Mapp compares?
Baro compares?
Fuel return screen is clean?
If so i would take fuel pressure/ICP/IPR reading's before and after a long pull.
Compare both. It will give you a direction to go in if its a oil issue.
Would also do a cyl cont test before and after.
Would also check for air in fuel.
Bill
Old May 21, 2008 | 08:01 AM
93f1505.0L's Avatar
93f1505.0L
EOT compares?
Mapp compares?
Baro compares?
Compare both. It will give you a direction to go in. WAG is higher IPR% after the pull.
Bill
Thanks. Ill do that one of these days. A buddy has a sanp on scanner that I can barrow. Oh and what it a cyl cont test?
Thanks
John
Old May 21, 2008 | 08:11 AM
MADVAN's Avatar
MADVAN
Thanks
John
The scan can do the test. It tests each cyl's idle output power.
Bill
Old May 21, 2008 | 08:28 AM
Action4478's Avatar
Action4478
EOT compares?
Mapp compares?
Baro compares?
Bill
What he said ....Higher IPR DC% is also my wag ...make sure on the level of oil & grade ...
Old May 21, 2008 | 09:45 AM
93f1505.0L's Avatar
93f1505.0L
Oil changes every 4000 miles with Rotella T 15w-40, about 1500 till next change. What cuases the higher IPR DC%?
