Seat interchange question
Old Feb 11, 2020 | 10:37 PM
1979_Red_Ford_Truck's Avatar
1979_Red_Ford_Truck
The seat in my 1979 F100 is pretty well shot, would a seat from an 80-91 F series fit in my '79?
Old Feb 11, 2020 | 10:41 PM
jberd45's Avatar
jberd45
The actual seat does; but you need the parts that bolt to the floor of your truck. So take the tracks off your seat and transfer those to any seat '73-'96.
Old Feb 12, 2020 | 09:36 AM
NorEaster603's Avatar
NorEaster603
when you say “transfer”, are you saying the old track directly fits newer seats? Or is there implied fabrication in that transfer?
Old Feb 12, 2020 | 11:17 AM
EQCMCAT's Avatar
EQCMCAT
NorEaster603,
I used a 1994 Ford F-Series bench seat that has the folding down center arm rest along with head rest, both features is what I was after (comfort / safety). You'll need to re-use your oem bench seat frame and re-mount a new seat to your original frame. The 1994 Ford bench seat I used mounted very easily onto my 77 F-150 OEM seat frame and I don't recall having to drill any additional holes.
No seat belt modification required.
Old Feb 12, 2020 | 02:58 PM
NorEaster603
Wow that is a clean interior! Thanks for the detailed response
Old Feb 12, 2020 | 03:31 PM
EQCMCAT's Avatar
EQCMCAT
Richard,
You're welcome and appreciate the interior compliant. Believe in using my trucks and stuff, but take care of them.
Did you notice the 1/2" aluminum pieces in the picture on the floor, I used one piece between the floor board and seat frame mounting bolt to raise the seat up just enough for me to stow a few things underneath it.
Old Feb 12, 2020 | 04:45 PM
fordguy2100's Avatar
fordguy2100
Originally Posted by EQCMCAT
NorEaster603,
Ive been thinking about doing this because the 87/96 trucks have the removable cup holders. I like the large cup holder with pocket in the front instead of the tiny one cup holder.... Would you have room to still put that in? I too have a manual 4x4 so the two sticks might get in the way.
Old Feb 13, 2020 | 04:23 PM
EQCMCAT's Avatar
EQCMCAT
Fordguy2100,
I haven't had any issue shifting my transfer case lever with the cup holder installed. But keep in mind that I have the seat back about 3/4 toward the rear. If a person needs the seat all the forward, the cup holder might get in the way of shifting the transfer case lever, I just haven't tried it, since I don't drive with my seat all the forward. The 1994 Ford F-Series bench seat came with a cup holder, but I changed it for one I got out of my local junk yard from a 2010 Ford Ranger, both mount in the same place, on the front of the seat, in the middle.
Old Feb 13, 2020 | 04:28 PM
1979_Red_Ford_Truck
I like the idea of having a cup holder! Luckily for me I have a "3 on the tree" so I could easily do the swap
Old Feb 13, 2020 | 08:57 PM
73 hi-boy 428 fe's Avatar
73 hi-boy 428 fe
In a highboy you can’t get the seat back far enough because of the fuel tank to use the cup holder and shift the 4WD stick.
Old Feb 14, 2020 | 10:34 AM
EQCMCAT's Avatar
EQCMCAT
I used to have the fuel tank behind the seat, but I removed it and that was after I installed the 1994 Ford F-Series Bench Seat. Even with the fuel tank behind the 1994 seat and my seat 3/4 to the rear, I didn't experience any transfer case shift lever problems, though my 77 F-150 isn't a sought after Highboy.
Shane Carruth
Jan 14, 2015 07:33 PM
wiesman2613
23
Apr 19, 2012 02:27 PM
Alex from GA
Jul 4, 2011 09:41 AM
voltson
Apr 4, 2010 05:03 PM
mavman
Jan 6, 2001 08:59 AM
