Are you looking for a single connector to use in each port? Or one the has the 3 and individual wires? Maybe a 4 pin flat connector, might work with a bit of modification? https://mechanicalelements.com/trailer-wiring-diagram/
The trailer 4 pin flat connector fits like a champ. I tried it behind the headlight switch and the one behind the glove box. And it can be bought at pretty much every place like Walmart, auto parts stores.
NO they are constant 12V power as far as I know. The one behind the headlight switch area provides power in a single wire up the A pillar to the dome light (other 2 ports are not used) and the one behind the glove box area provides power to the glove box light and cig lighter. Again though just one port used, it is a T wire) At least on my 79 F250 it does.
