gpr ?
Old Oct 12, 2007 | 10:07 PM
61 uni's Avatar
61 uni
gpr ?
Now that's she's running again, I want to know Whick gpr terminals are "hot"(have voltage) when the engine is running and the plugs have kicked off. The bottom 3 (see pict) have voltage. This is the way it is supost to be. Right???
Old Oct 13, 2007 | 08:49 AM
tjbeggs's Avatar
tjbeggs
that sounds correct. One large terminal has power one small terminal has power and then the other small terminal when the PCM isn't supplying ground has power on it also. Then the PCM commands the the GP's on it grounds the control circuit and energizes the GPR.
Old Oct 13, 2007 | 09:00 AM
61 uni's Avatar
61 uni
Thanks. I wanted to be sure my advance auto relay didn't burn up my wiring. You guys rock
