What is this connector, and what does it go to?
The piece on the top right looks like it may have gone to the low vacuum sensor.
Part on the bottom left almost looks like the tach sensor connector, but it should be over near the IP.
Low vacuum sensor is below and to the right of the vacuum reservoir ball with one vacuum line and one electrical connection with 3 wires in it..
Ok more info,
the wires are
Black with light green strip
Green with Yellow stripe
Red with Orange stripe
Yellow with Light green stripe
Beyond that, I Think Dave S. has part of it. The GRN/YLW and the BLK/LTGRN go to a connector that Dave pointed out for the Tach sensor, even though i don't have a tach or sensor, the connector in front and top of the IP..
I still don't know what the other two wires are for. Any more info Dave? those two half connectors go together. same wires on each one.
the wires are
Most of the 86 trucks have the tach wiring in the harness weither one was installed ot not.
I was headed up to check my truck, but it is pouring the rain down, so that will be later.
The picture I posted on the inner fender wiring has a few extra things installed.
But it looks like you are missing several things on yours.
If I remember right there is anouther connector back toward the heater motor that looks like that, just don't remember what it goes to.
And looking at your picture, I do see the low vacuum sensor is still hooked up.
I went out in the dark with my flashlight to find out more. My horn wire is dark blue, so that solves that part. The two other wires (the red/orange and the yellow/green) go to the two big wires coming off of the alternator. They get spliced in inside the wire harness. Looks factory, but can't tell. My alternator has 4 wires, two big and two small. Small ones on top. Is that normal? I thought these had external regulators? I don't have one on the fender.
Fishin76
1999 to 2016 Super Duty
07-03-2015 08:20 PM
Fishin76
39
10-29-2010 12:42 PM
Fishin76
01-06-2010 08:34 PM
