Original Positive Battery Cable?
Old Jan 27, 2020 | 04:57 PM
kr98664's Avatar
kr98664
Greetings All,
Does anybody here have an original positive battery cable on their truck? I'm talking about the short cable from the battery's (+) post to the adjacent starter relay on the inner fender. I replaced mine years ago due to some corrosion. The replacement is a generic cable that is too long and I had to loop it around to make it work:
I'd like to clean up the appearance, but it's been so long I don't remember what the original looked like and how it was routed.
I'm pretty sure the battery is correct and installed properly. The posts are on the aft side, and the positive post is outboard, closest to the fender.
Old Jan 27, 2020 | 05:05 PM
Kramercd's Avatar
Kramercd
How long is your current cable? I'll dig my harness back out and see what I've got. Where'd you steal that battery hold-down? I've been eyeing one on ebay but I need more important parts for now. You think you could snap me a picture of the hold down bolt on the backside of the battery? Between two trucks, I think I have one slotted strap on the fender. Haven't found pictures of a stock setup yet.
Old Jan 27, 2020 | 05:27 PM
Kramercd's Avatar
Kramercd
Alright, my cable looks exactly like yours, measures 13.5" from end to end on the connectors. Mine has memorized this shape.
But I may be in the same boat you're in. Your battery is oriented the same as mine is in what photos I have, sadly I don't have any showing the positive cable. My cable looks like it has been hammered on for 38 years, but I don't guess that makes it stock. I can go dig out my fenders and mock up an intervention.
Old Jan 27, 2020 | 05:32 PM
kr98664's Avatar
kr98664
I think that particular cable is 12", but am not positive.
Get it? Not positive about the positive cable. Yeah, I know, keep my day job. I don't get no respect...
The battery hold-down in the picture is the factory original. I replaced the battery last week and the new one is about 1/4" wider. Seemed like the original bracket had just enough slack to fit, if I just pushed a little harder. Doh, too much. It's now a 2-piece bracket and not doing much good like that. I've got something hokey rigged up until I can fabricate something better. But while I'm at it, I want to clean up that positive cable.
If you want an original bracket, Dennis Carpenter makes nice reproductions. $15 direct, but with $10 shipping. Amazon and eBay have them cheaper, same source, $20 total with free shipping:
Amazon Amazon
The tie-down bolts I have are not original. They are just ordinary replacement J-bolts from my local parts store. Not sure a picture would be of much use to you. I can still take one, but you'll have to wait for this Oregon monsoon to pass. April work for ya?
Old Jan 27, 2020 | 06:43 PM
Tedster9's Avatar
Tedster9
Nattering Nabobs of Negativity
Currently I'm trying to resist making jokes about stuff like that.
Old Jan 27, 2020 | 06:44 PM
Kramercd's Avatar
Kramercd
https://m.youtube.com/watch?v=VGg_HTls8ME
https://www.amazon.com/gp/aw/d/B07HR...b_b_prod_image
I hope I'm not still waiting to hook up the battery in April. About to put the cab back on now. If I can find my new prothane body mounts, with any luck they are still on the corner of the table where I set them a year ago. I saw some parts and pieces of different batter hold down bolts, saw one, not sure what it was for, had a j bolt, looked like it hooked a vertical slot on a trapezoidal plate that looked like the bottom skinny side had a hook to fit the vertical slot on the fender. Seems like a lot of parts to use on something like that.
Old Jan 27, 2020 | 08:00 PM
Franklin2's Avatar
Franklin2
I would think a longer cable would last longer with less strain on the ends from vibration.
Old Jan 27, 2020 | 09:17 PM
kr98664's Avatar
kr98664
Makes sense, but if too long you end up with extra slack and the cable can bounce around.
I do plan to go shorter than what I have in the first picture. I'm making a new hold-down bracket but it will be metal, not plastic. I don't want the positive cable rubbing against this new metal bracket.
Old Jan 27, 2020 | 10:18 PM
Kramercd's Avatar
Kramercd
Seems like it'll see more strain as stiff as those cable are and being forced over. Didn't Gary Lewis pick up a very low mileage Bronco? Wonder if he got pictures of the cable.
*edit*
Looks like he documented one, gorgeous truck. http://www.garysgaragemahal.com/1983...-survivor.html The cable has 1 90* "bend" the cable comes out perpendicular to the lug like your negative does. Could go the same thing with a shorter cable that comes out straight.
Old Jan 28, 2020 | 10:21 AM
kr98664's Avatar
kr98664
Looks like he documented one, gorgeous truck. 1983 Bronco Survivor - Gary's Garagemahal (the Bullnose bible) The cable has 1 90* "bend" the cable comes out perpendicular to the lug like your negative does. Could go the same thing with a shorter cable that comes out straight.
Ah, very helpful. In those pics, I noticed the starter relay looks to be located several inches aft of where mine sits. Also, mine is angled forward slightly, where that one is straight.
Here's another view of mine:
I wonder if I should relocate my starter relay to match Gary's example. That would help reduce the bend required on the cable.
Old Jan 28, 2020 | 04:06 PM
FuzzFace2's Avatar
FuzzFace2
Only picture I have of my 81 F100 but can get more if you want.
Also if you look at Gary's picture it has a different battery clamp end where the cable comes out the side not the end like ours.
Dave ----
Old Jan 28, 2020 | 04:22 PM
KULTULZ's Avatar
KULTULZ
Post
This is where the absence of NUMBER DUMMY is felt.
You need the MPC to get the PN of the POS CABLE.
Old Jan 28, 2020 | 04:36 PM
Kramercd's Avatar
Kramercd
You'd be amazed at what Gary has compiled over at his place. Battery Cables - Gary's Garagemahal (the Bullnose bible)
Good stuff in this thread, including a photo of a cable that has a newer part number on it. https://www.ford-trucks.com/forums/1...ry-cables.html
Old Jan 28, 2020 | 05:07 PM
KULTULZ's Avatar
KULTULZ
Post
OK...
It is 10"...
Be advised the PN PREFIX DIPZ an AUTOLITE/MOTORCRAFT dedicated PN and not the original P&A SERVICE PN. The AUTOLITE cables came through with BLUE SHEATHING (a few fit all).
The STAR indicates the part was deleted (both P&A and AUTOLITE) and not replaced. It has to be bought aftermarket or fabbed.
Old Jan 28, 2020 | 07:04 PM
Lariat 86's Avatar
Lariat 86
This is what my 86 looks like. I’ve owned it since the late 90’s and haven’t changed nothing but the battery and the j-hooks. The original j-hooks almost rusted into. The cable is 10”.
This is what the original nut looked like
10” cable
Original nut for j-hooks
