Sponsored by: Auxito
P0455 Code
Old Oct 13, 2003 | 12:21 PM
florit's Avatar
florit
Question P0455 Code
My check engine light has been going on and off intermittantly now for a couple of years. Took it to Ford a couple of times and each time they replace something different but the light keeps coming back on eventually. I went to AZ because I got tired of dishing money out to Ford without the problem getting resolved. When the guy at AZ hooked up, a code of "P0455" came out with a message saying 'emissions leak (large)". I looked all around my exhaust system and found that where the clamp holds the pipe going into my muffler had shifted, and there was exhaust coming out there. I say that because you could see where the soot had built up shooting out from the bad connection. I've just fixed the conection by loosening, then repositioning and retightening the clamp. Now I'm waiting to see if the light will reset itself. After all this, my question is would that cause the code I'm getting or did I just fix something else that needed fixed and I still have a problem?
Old Oct 13, 2003 | 12:41 PM
florit's Avatar
florit
I forgot to mention, it's a 97 F150 supercab.
Old Oct 13, 2003 | 04:28 PM
Racerguy's Avatar
Racerguy
Hi florit and welcome aboard
A P0455 is for the Evaporative Emissions system. The system has detected a large leak or no purge flow.
It could be something as simple as a gas cap that isnt sealed properly but in my experience it is quite often a problem with the canister purge valve or solenoid or the wiring to them.
The canister purge system is at the back of the truck, above and behind the rear axle. There is one wiring harness going to it. I've seen those corroded and torn off. The wiring harness connects to the canister purge valve which can also malfunction. Mud in them also can cause the code. If the wiring looks ok I think I'd pull the purge valve out and see if it's plugged up.
Old Oct 18, 2003 | 03:16 PM
florit's Avatar
florit
Thanks for the feedback Racerguy. I checked the wiring harness, it looks to be in good shape so I pulled the canister assembly, wasn't that bad to do, and I took apart the whole thing. Besides being dirty on the outside everything inside looked clean, dusty perhaps but no mud or any major dirt or clogs that I could tell. Any thing else I should look for???? OH, say I fix whatever is causing the problem when will the light go out??? I understand I have to drive 3 "drive cycles". What defines a drive cycle for my vehicle?? Thanks for the help.
Old Oct 18, 2003 | 08:41 PM
Racerguy's Avatar
Racerguy
Probably the next thing to do would be to check the resistance of the CV solenoid. It should be 48-65 ohms. If not you should replace it. If that isnt the problem you might have an EVAP leak which will probably have to be checked a shop with a smoke machine. With a proper scan tool the tech can open and close the different solenoids etc while filling the system wtih smoke and then checking to see if the smoke leaks out anywhere.
Once the problem is fixed you can just pull a battery terminal off for 10 minutes or so which will clear the code and turn the light off. An OBD2 drive cycle consists of some highway driving, some slower driving, medium accelerations, idling etc. Normally a few days of normal driving will complete a cycle. During the drive cycle the truck's PCM looks at all the different sensors etc and either passes or fails them.
Old Oct 20, 2003 | 07:14 AM
florit's Avatar
florit
I have a digital multimeter at work, I'll be checking that today. If I pull the battery terminal to clear the code and the problem still exists will the light come back on immediately? If the light doesn't come back on how long do I have to wait to be able to get it inspected?
Old Oct 20, 2003 | 08:56 PM
Racerguy's Avatar
Racerguy
Any luck with it?
When you ask about having it inspected are you talking about emissions testing?
If you are talking about that, you will have to do a complete drive cycle with no problems before it will pass testing. After clearing codes the PCM will have a P1000 code in it which means that all the "monitor" tests are incomplete and further driving (hopefully) or repairs is neccesary.
Old Oct 22, 2003 | 09:47 AM
florit's Avatar
florit
Before I got a chance to check the ohms on the solenoid the check engine light reset itself. So I don't know if it was due to me messing around with the purge canister assembly and wiring or if it was coincidence. Either way it passed emmisions and I'm legal for another year. If it comes back I'll check the wiring to the solenoid again. If it clears after, I may be on the right track. Thanks for the help Racerguy.
Old Oct 22, 2003 | 11:14 PM
Racerguy's Avatar
Racerguy
Thanks for letting us know how it went.
You may have knocked enough dust out of it to cure it.
mfp4073
1983 - 2012 Ranger & B-Series
May 7, 2015 10:25 PM
zurgur
Escape & Escape Hybrid
Feb 9, 2012 11:52 AM
odgmatt
May 21, 2009 10:35 AM
xpn150
3.8 & 4.2L V6
Oct 25, 2006 09:49 AM
ty5000
1997 - 2003 F150
Nov 15, 2002 11:49 PM
