P0455 code
Old Oct 23, 2006 | 08:32 AM
xpn150's Avatar
xpn150
P0455 code
ok, have had this code reset at autozone 3 times now. 1st time there was a hose off from the firewall that we reconnected and the light didn't come off for a few days. it has come back on twice now, but no obvious hoses hanging off. should i take it back to the dealer and see if they would see if they crossed some hose or forgot to reconnect one while repairing the bypass hose leak?
the fault says it may have something to do with connection to a charcoal canister? can anyone help me locate that on a 4.2?
thanks
Old Oct 23, 2006 | 10:35 AM
BrianA's Avatar
BrianA
split thread. reference original post:
https://www.ford-trucks.com/forums/5...hose-leak.html
First thing to try: clear the code and then replace the gas cap with a new one.
Old Oct 25, 2006 | 09:49 AM
Hamberger's Avatar
Hamberger
Code 302
Seeing the 3.8l forum does not take new post I also have a Code question.
I got a 95 3.8l in a Windstar. I got not signal to No. 2 injector (Checked injector -ok., checked harness with a NOID light, no blinking signal, light does not come on. Checked injector with stetoscope, no injector pinging like you get on the other 5 injectors.)
The only intermittent code that the PCM puts up is a Code 302 (Cylinder No. 2 Misfire Detected)
I am positive that No. 2 cylinder is not getting fuel as you can feel the engine run like it is missing a cylinder during idle and during accelerations. The engine light only comes on once in a while and everytime I get it I pick up a Code 302 on my scanner.
What could be causing the lack of a proper signal to the No.2 injector?
Change the Upstream O2 Sensors as there seems to be some weired crosswiring that only involves No. 2 injector according to the Haynes repair manual wiring diagram.
What is going on? A broken wire between the PCM and the injector? PCM bad?
Any help would be much appreciated.
Seb....
AMG-SM
29
Sep 9, 2019 11:47 AM
MOSPARKY
Oct 11, 2011 11:52 PM
RÖENTGEEP
16
Feb 13, 2009 08:48 PM
greywolfmage
1983 - 2012 Ranger & B-Series
Feb 24, 2007 06:18 PM
