TPMS
Old Jan 31, 2020 | 03:29 PM
tbear853's Avatar
tbear853
Originally Posted by 1saxman
My truck came with a regular wheel/tire spare. I'm pretty sure it has TPMS.
No, it does not have a TPMS in it unless you added it.
Cold PSI does not mean the coldest on that day, it's ambient temp, like not heated by fire, sun, high speeds, long trip, heavy load, etc. If the tire has been driven 45 miles at 127mph and the roadway is 112 degrees, the tire is not at ambient temperature. If it's between 70 and 90 degrees in the day but hits a low of 34 degrees at 2:00AM, the correct time for setting psi is in the day unless you drive a lot at 34 degree temps. A tire set at 34 degrees will have more psi-s when temps climb into the '90s.
I check / adjust as needed at start of seasons.
If adjusted in Summer, it's gonna be lower in winter.
If adjusted in winter, likely OK in summer as I use only good air and it can seep out through pores in rubber over time.
I run 40psi minimum in P275/55-R20s, but often will go 42.
My '07 has it's OEM sensors still, too, so far no lights except when a tire was low, but they've only been awake for 65,xxx or so miles.
Good battries I guess.
Old Feb 7, 2020 | 03:54 PM
1saxman's Avatar
1saxman
On the cold pressures, its really simple. When it gets colder, you probably will have to pump up the tires. When the manufacturer says 'cold', as they always do, it means not driven for an hour or longer. I like to do mine first thing in the morning before the sun hits them. All you have to do is to not let the cold temp get below the placard. You also don't want it significantly higher than the placard on the cold check.
Anyway, my original battery was in the process of failing. The first time I saw the TPMS light was immediately after a slow crank and almost no-start. Coincidentally I spotted a metallic object on the front tire so I took the truck to my tire/general work shop. The little pin they found in the tire was barely stuck to it and did not puncture it. They tested the battery in every way and said it was good. However, I still was having weak cranking, and the TPMS would pop up. Finally I realized I have to replace that battery and I just put the new one in. 13 years on a battery is long enough . The old one was 540CCA and I went ahead and sprung for an 840. Boy, does the starter spin now. And, no more TPMS. I'm not sure what the connection was but obviously severe low voltage can play hell with electronics.
Old Feb 7, 2020 | 05:53 PM
Fifty150's Avatar
Fifty150
close call
Old Feb 7, 2020 | 08:05 PM
cmorningstar01's Avatar
cmorningstar01
Cell phones, cell phone chargers and other electronic equipment inside the truck and outside the truck can cause a TPMS Fault, One or our cell phones will occasionally trigger a TPMS fault in my truck, it will reset after I drive the truck a bit, the same phone also triggers a TPMS fault in my 14 Escape.
It has happened to me over 1/2 dozen times, the first time I thought the a sensor was bad and had it replaced, it then happened several times after that and I started doing some research and found out that some devices can emit rf interference that will cause the system to go into TPMS Fault mode
Old Feb 11, 2020 | 04:44 PM
1saxman's Avatar
1saxman
It was definitely the battery causing extremely low voltage which temporarily affected the TPMS. There was no point in pushing the battery as far as I did and I'll never do that again. I knew better and I recognized what was happening when it 'slow-cranked' the first time. I guess if I ever have another one last ten years, I'll replace it whether its good or not. But I'm glad I ended up installing the new battery because the shop would not have cleaned out the battery box or used 'Corrosion X' on the terminals.
Old Feb 19, 2020 | 11:15 AM
tbear853's Avatar
tbear853
because its a base model without separate tire pressures - its just the light or no light.
That's all my '07 FX4 does?
Our Mustang is the same.
Her '19 Forester reports pressures though.
Old Feb 19, 2020 | 11:28 AM
WWR's Avatar
WWR
Yep the great problem with federally mandated equipment like this is some (most) manufacturers will opt for the least expensive equipment to meet the bare minimums
Apparently Dodge (er um Ram - IT'S A RAM!) of all manufacturers uses a system that knows which sensors are at each wheel, including automatically figuring it out when a tire rotation has occurred.
But both my '07 F150 XL, '08 F150 XLT and '11 F350 XL are just all or nothing - an error warning or light for ANY error ANYwhere. Not super helpful.
I'd be glad to never see TPMS again - I was raised learning to drive when a motor vehicle operator was expected to have other responsibilities like regular tire pressure checks, oil level checks and using side and rear view mirrors. Now we're just glad if a driver can go a couple blocks without having to have "collision avoidance" save them
Old Feb 21, 2020 | 12:21 AM
tbear853's Avatar
tbear853
Tape over the light.
You mention rotation. Odd, I rotated tires in about 2010 or 2011, no lights. Bought new tires this past November of 2019, marked my wheels for position, Discount Tire mounted them and still mixed them up, and then they had to reset the TPMs they said because it was causing a light?
I wondered why didn't I get a light when I rotated them that time some years ago?
I had also mounted and run some like new take offs from a '09 F150 in 2015, but I had hauled them to my buddy's shop and did them one at a time myself, so then they went back like they were put in that earlier rotation, so I would not have expected a light then in '15.
Old Feb 21, 2020 | 09:39 AM
steve(ill)'s Avatar
steve(ill)
i dont think ROTATION means move from the front to the back... If you ROTATE ( spin the tire by moving down the road), that will turn ON the sensor and it will work.. IF it sets for a long period, it could turn its battery OFF and not read untill you are back on the road.
Old Feb 21, 2020 | 09:56 AM
WWR's Avatar
WWR
I'm not sure if these Fords know left to right but in the case of varying suggested (as per door jamb sticker) pressures they'll know front to rear, at least on the SuperDutys. It's a problem for SuperDuty owners 'cause many of us will run with lower rear pressure unloaded, then go up to 80 for loads, but the Ford (and/or our gubermint) in their infinite wisdom wants to see a percentage of the door jamb sticker pressures at all times.
I don't know if the variance in F150 pressures front to rear is enough to be noticed by most owners in this situation.
The problem with Ford's system (and many others) is even though the vehicle may (or may not) KNOW which sensor is bad the dash isn't sophisticated enough to tell you, so you're left guessing and checking all 4 pressures. If all 4 pressures are good, you still don't know which sensor is then dead or defective without having the tool to "read" each sensor, physically at each wheel.
Furthermore, while some vehicles automatically know when tires have been rotated to different positions, most rely on the USER to recalibrate after a rotation. If this has not been done (and quite often it isn't), the vehicle may say "left front" is low when in fact that has since been moved to "left rear." In other words, garbage in, garbage out - it only knows as much as "we" have told it regarding position.
On the SuperDutys with a text DIC "taping over the light" simply isn't enough. You'll get a text message dead center of the dash each time you start, and again 25 miles into driving, accompanied each time by an audible chime. I'm wearing out that RESET button on my steering wheel LOL. Taping over the DIC is dumb 'cause it might someday tell me something else I'd want to know. FORSCAN can apparently remedy this, though.
cjben
Transit Connect
13
Nov 9, 2018 02:18 AM
homerj
May 12, 2018 06:34 PM
meborder
Jun 24, 2016 11:28 AM
Anomic
Jan 26, 2014 05:10 PM
jwford
2004 - 2008 F150
Feb 23, 2009 10:44 AM
