So, when you first turn on the iDash, the system gives you a screen to enter the engine size. Initially it shows 0.0, so you enter 6.7 and move on. If you manually enter the engine size, the system will not show the soot %. If you go through the menu and select 6.7 from the dropdown menu, it will show the soot %. Anyway, I got it working so for those getting a new device, do not enter 6.7 as the engine size, you need to select 6.7 from the menu.
Glad to hear it was something simple. Now on to finding out what your machine is up to.
Originally Posted by senix
thanks for reporting back on the mystery. Makes sense.
So now... what is your distance from last regen showing as? Do we have another unicorn or not?
