Replace both Bumpers recommendations
Old Jan 19, 2020 | 08:45 PM
wahoouva2's Avatar
wahoouva2
Just purchased a 2003 Excursion 7.3 and need to replace or repair both bumpers. The truck is an Eddie Bauer with the beige colored bumpers and both the front and rear have rusted in the corners and the paint has flaked off. I think the truck could use some more chrome but I haven't been able to find any good recommendations on a OEM vs replacement brand. Are there good videos on the replacement?
Also noticed the fuel tank skid plate is pretty durn rusty. What do folks recommend on converting the rust and painting?
Thank y'all. I'll be posting more as I get into it more as my list of "want-to's" is long.
Old Jan 19, 2020 | 09:10 PM
Bently_Coop's Avatar
Bently_Coop
08+ rear bumpers look pretty sharp, check the tech folder for installation tips.
My 99 Super Duty was hit and a new bumper Capa certified through Keystone was about the same cost as a 20 year old used bumper from a wrecking yard.
Old Jan 19, 2020 | 10:06 PM
Eaglescout94's Avatar
Eaglescout94
As far as painting the skid plate POR15 all the way. Ive done parts of my frame and it holds up great. Planning on painting more parts of the truck this year with it to convert the rust and make it look good.
Old Jan 20, 2020 | 04:56 AM
nitro_rat's Avatar
nitro_rat
The crash parts aren't the same quality as OEM. Thinner metal and cheaper chrome. The EB painted stuff is much more expensive. If you want chrome search car-part.com. Plenty of rust free stuff from southern trucks. If your tan plastics are in good shape that will save you a lot, otherwise you'll want to find bumpers off a Limited Ex, chrome with tan plastic.
Old Jan 20, 2020 | 03:13 PM
Lance Helmert's Avatar
Lance Helmert
I had trouble with POR15 peeling. I used KBS coatings on my Kenworth and it's holding up very well on what was sand blasted. I had a few parts that had nice paint yet, so I scuffed them and sprayed the KBS. I didn't know it then, but I was supposed to spray their fusion primer on the scuffed paint and then the KBS Rust Seal. You are also supposed to use the fusion primer on top of the Rust Seal if you want to paint it. So the KBS peeled on the painted parts due to my mistake.
I tried Eastwood Platinum Rust Encapsulator on our Excursion. It went on very well and covered much better than I expected. I'm still working on the EX, so I don't know how it's going to hold up yet. It seems to have adhered well to both metal and paint.
Old Jan 20, 2020 | 08:28 PM
wahoouva2's Avatar
wahoouva2
Bently, Thanks for the response. I couldn't find anything in the tech folder about how to with steps to replace front and rear bumpers. Any suggestions? Haven't found YouTube videos either.
Thank you!
Old Jan 20, 2020 | 10:30 PM
unleashd's Avatar
unleashd
Thank you!
@wahoouva2 There is nothing technical /difficult about removing/reinstalling the bumpers, except they are a bit heavy if you are doing this yourself.
Front bumpers are held in the front/center by 4 bolts, 2 each on each side of the winch hooks. In addition, there are 2 bolts in the back. 1 each on the left & right that are holding the corners in. Rear bumpers are held by 4 bolts and a bracket. 2 bolts on each side. Rear bumper is much more heavier than the front as it has a heavy & strong inner frame. Here are some pictures to give you an idea how the front bumper mounts.
As far as replacements, ou can pick your choice of bumpers from the 5 years that the Excursion was made OR from 99-'16/'17 superduty F250/350. See below for the 2 ways that I tried it on my 2 excursions and make your choice. On the red excursion (2000 7.3), I used the front and rear bumpers from a '15 or '16 superduty. On the grey excursion (2003 7.3), I went with a front bumper of a '06 and the rear bumper from a '15 superduty.
Before & After
Before
After
Rear bumper
Old Jan 20, 2020 | 11:27 PM
ShelbyHauler's Avatar
ShelbyHauler
I searched the internet car parts until I found a site that gave me a discount. It arrived with one corner bent and cracked, but my MIG welder took care of that. Painted it like the original and the front of the X is looking like new. Seems to be a quality part, the metal was very close to being as thick as the original. No fitment problems at all. My plastic was in pretty good condition, the only thing I need are the clips that hold the round studs on each end.
Old Jan 21, 2020 | 01:45 AM
Bently_Coop
Thank you!
​​​​​​Sorry about that, I thought there was. As mentioned below it is a pretty simple swap.
@mecdac shows a list of tools before pulled from his parking sensor thread.
Originally Posted by mecdac
Tools you will need:
21 MM deep well socket
Breaker bar
1/2" drive ratchet
Dremel
Jig saw
File
Grinder (take about 1/8" off the frame)
Flat and Phillips screwdrivers
burnthelight88
17
Jan 29, 2018 11:49 PM
SuperDutyDoug
Jul 2, 2015 03:29 PM
nitropolaris2
2009 - 2014 F150
33
Aug 8, 2014 07:08 PM
1 Ton Tommy
Jan 12, 2008 01:16 AM
shooer
Jan 22, 2007 01:05 AM
