Knobs
Old Jan 17, 2020 | 10:29 AM
slabhunter's Avatar
slabhunter
How do I remove the black plastic ***** from the dash (lights, wipers, choke etc.)? Next how do the chrome bezels come off?
Old Jan 17, 2020 | 10:45 AM
TA455HO's Avatar
TA455HO
Lead Gopher
They are each a little different than the other.
For the lights **** you'd want to reach behind and find the **** button to press that releases the shaft and **** as a unit.
For the choke there is a nut on the back side that needs to be completely loosened and then the entire choke cable pulls out through the dash and rear nut. Bezel is part of the whole assembly.
Wipers - probably a spring clip inside of the **** - these can be a bear. If it is an Allen head set screw they are much easier. Then once the **** is removed then you can use a tool to remove the bezel nut.
The bezel nut for the lights, wipers and fan look essentially like this
The tool I use to remove them looks like this
Old Jan 17, 2020 | 10:54 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Here's a picture of a couple of choke cables. Both NOS but the one in the wrapper is the universal C5TZ-9700-N which was cut to size and it has a finer thread for the rear nut and it also has the Allen set screw to allow removal of the **** from the cable.
Old Jan 17, 2020 | 12:18 PM
Oilboy34's Avatar
Oilboy34
Hey Chad,
The little ivory colored insert in our choke **** is missing. So if I understand you correctly we have to replace the whole cable assembly not just the ****?
Old Jan 17, 2020 | 12:23 PM
mulegal's Avatar
mulegal
Oilboy you can buy the little ivory discs from DC if that's all you're needing
Old Jan 17, 2020 | 12:36 PM
TA455HO's Avatar
TA455HO
Lead Gopher
You can get just the insert from places like Dennis Carpenter. The original choke cables came with the **** already installed. You can remove the whole **** and replace it by either gluing a new one on or using one with the built-in Allen set screw.
https://www.dennis-carpenter.com/en/...-white-plastic
https://www.dennis-carpenter.com/en/...okeheater-temp
The choke **** was original part of the assembly - glued on I imagine - to the metal rod that controls the center wire.
Old Jan 17, 2020 | 01:13 PM
User 71024's Avatar
User 71024
Or you can get fancy and go chrome from CJponyparts.com ;;
Mearntain
13
Jul 8, 2019 12:56 PM
rnelson664
Jan 29, 2015 05:45 PM
Vsanzbajo
Dec 22, 2013 01:20 PM
clinkfield
Jul 28, 2013 08:14 PM
santi2322
Jan 29, 2009 12:46 PM
