Sponsored by: Kumho
Need some spring hanger dimensions
Old Jan 8, 2020 | 01:32 PM
J_Tetford79's Avatar
J_Tetford79
Making up a couple front spring hangers for my ‘79, and mine rusted and broke apart so bad it’s impossible to get a couple measurements besides for the frame mounting holes.
What I’d like to know, is the inside space between the tabs where the spring sits in. My bushings are also a little sketchy so I want to make sure I have a good tight fit for the new ones when they arrive. I’m thinking if I have 3.25” of space there should fit fine. But want to be sure.
Other dimension I could use is the space between the leaf and the chassis. So how far stuck off the frame I need the bracket spaced. If I had the truck near me where I’m making the brackets it would make it a lot easier, but I don’t, so maybe someone has a hanger laying around and could take a couple quick measurements. Or if anyone’s built a set feel free to post some pictures.
Again this is all for the front mount of the rear leaf for 3” springs. Thanks
Old Jan 9, 2020 | 12:30 PM
mark a.'s Avatar
mark a.
The width in mine is 3 1/2" . From the frame out to the inner edge of the bracket is 1 11/16"
Old Jan 9, 2020 | 01:12 PM
J_Tetford79
That’s perfect. Thanks very much
Old Apr 24, 2020 | 06:29 PM
J_Tetford79
I wasn’t lying
christurney77
1947 and Older Ford Trucks
Mar 1, 2012 11:47 AM
JM5034
Dec 11, 2008 06:26 PM
brian0357
Offroad & 4x4
Apr 14, 2006 07:13 PM
Jag Red 54
Jan 24, 2005 03:03 PM
51dueller
Apr 8, 2003 01:24 PM
