Sponsored by: Real Truck
'01 7.3 w/ 4r100 issues
Old Jan 5, 2020 | 07:00 PM
Mearntain's Avatar
Mearntain
As the title states, I've got a 2001 F250 7.3 w/ a 4r100. I havent driven it much recently, probably only 500 miles over the past couple years combined. Mostly just start it occassionaly and drive it around the yard as of this year.
I remember recently occasionally getting a "hopping" feeling up and down on occasion going down the road (especially once the TC engaged), which makes me lean towards thinking torque converter issue. Forward and reverse worked fine last start a month or two ago.
Started her today to drain some water out the bed and everything seemed fine for the half mile I drove down the road, excluding a slight slipping sound almost (as if you were slightly push the clutch on occasion in a manual and hear the engine rev slightly - i was barely accelerating while driving since it was a cold start). I went to turn around, and it wouldnt go in reverse. Just revved when I hit the gas.
After popping about 12 blood vessels, I managed to push the truck backwards far enough so that I could pull out forward. Put it in Drive and engine sorta revved when hit the gas at first but then "caught" and I limped back home. I had the "hopping" return while only going about 25 on the way back. When I stopped in the drive way, the truck acted like wanted to keep going and didnt disengage like it should when on the brake. Put it in Park and engine idle returned to normal.
Is this torque converter symptoms or something different I need to deal with?
Thanks
Old Jan 5, 2020 | 07:37 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The first thing I recommend checking is the fluid level. All of those symptoms can be caused by low transmission fluid.
Old Jan 6, 2020 | 10:10 AM
Mearntain's Avatar
Mearntain
I will double check that today and report back with my findings. Thanks
Old Jan 6, 2020 | 03:04 PM
Mearntain's Avatar
Mearntain
Got the truck started and went to check the trans dipstick and it was bone dry. After adding about a half a quart, I notice I had an "oil" leak, unsure of what type. The grounds so wet right now, i couldnt get a good look except with my phone.
Does this by chance happen to be my trans cooler leaking here (pic taken on passenger side)? If so, that would make sense as to why my fluid was low, hopefully the only cause of all my issues as well.
Old Jan 6, 2020 | 07:09 PM
TwiceStroked's Avatar
TwiceStroked
Looks like Remote filter lines.
Old Jan 6, 2020 | 07:12 PM
Mearntain's Avatar
Mearntain
Whats the remote filter lines? Is that the same as trans cooler lines?
vanrebl
Dec 26, 2019 07:50 PM
tjc transport
Oct 23, 2018 09:07 AM
Hoss5504
Apr 4, 2017 08:59 PM
truck7575
Oct 28, 2015 09:19 AM
FF4Life
Jul 23, 2010 01:39 PM
