Sponsored by: Real Truck
2015 Ford Remote Starter install
Old Dec 31, 2019 | 11:26 PM
ALL THROTTLE's Avatar
ALL THROTTLE
I've installed a factory remote start in my 2015 F250 XLT and can not get it to work. I've found the spreadsheet for a 2016 F250 and enabled the start based off that information. The kit I installed uses the separate key FOB for longer range. The kit included;
Antenna DA8Z-15603-A
Wireless remote EL3Z-19G364-B
Base security DL3Z-19A361-A
I've must've missed something and any help would be appreciated.
Old Jan 1, 2020 | 04:57 AM
Just Strokin's Avatar
Just Strokin
Do you have the base remote start installed? Do you have the hood switch installed? Did you learn the security module to the truck?
Not sure why but the install instructions show you need the RF Antenna/base remote start. You would not need the IKT/key fob. You can try the install without it by following the instructions.
File Type: pdf
Old Jan 1, 2020 | 01:26 PM
ALL THROTTLE
Just Strokin, I wanted to let you know that I resolved my remote start issue. Turned out that I misread the program sequence for the FOBs. The part that I missed was the that the security system disable jumper had to be removed to program the FOBs.
Thanks for you help.
Old Jan 1, 2020 | 04:31 PM
Just Strokin
Which fob are you using? It is the bi-directional? What is the FCC-ID on it or part number?
Old Jan 2, 2020 | 09:13 AM
Just Strokin
The following remote is one way.
Info on back of fob
FCC ELVATJH
Model 4360307
IC 3671B 43603070
The following remote is bi-directional
Info on back of fob (a used fob on Bay might have Subaru sticker on it but will work)
FCC ELVATRKC
model - two button 4360321 one button 4360320
IC 3671B-43603200
one button (start)
DS7Z-15K601-G
two button (start and panic)
DL3Z-15K601-A
moose_j9
Dec 16, 2010 11:42 PM
gradynh
2009 - 2014 F150
Aug 21, 2009 04:31 PM
INFLUENCER
2004 - 2008 F150
Feb 19, 2007 05:12 AM
elemirand
Jan 8, 2007 11:16 AM
Gen Strongman
Electrical Systems/Wiring
May 25, 2004 03:35 PM
