Choking on gas
Old Dec 24, 2019 | 11:36 AM
catfishpizza's Avatar
catfishpizza
Choking on gas
Hi friends. My truck sat a couple weeks and now it won't fire up like it normally would. Also, leaking gas from the bottom of the carb. Any thoughts or suggestions would be much appreciated. Merry Christmas and Happy Holidays!
PS - The last time I ran the truck my 3 year old closed the manual choke and it took me awhile to realize that was why I couldn't get it to start. Fear that did some sort of damage to the carb. ???
Old Dec 24, 2019 | 05:45 PM
John89's Avatar
John89
Stuck float? Tap the side of the bowl with the handle of a screwdriver and see if it fixes it. You may have to pull it to get a permanent fix.
Old Dec 24, 2019 | 06:29 PM
FuzzFace2's Avatar
FuzzFace2
It would help if we knew what motor / carb we are working with to better help you.
Are you sure the gas is leaking out the bottom of the carb?
A choke pulled or stuck on will not hurt the carb but will flood the engine and could foul the plugs to the point of not starting.
Dave ----
Old Dec 24, 2019 | 07:58 PM
reecieboy's Avatar
reecieboy
Had the same idea.
Old Dec 25, 2019 | 12:34 PM
CelticOne's Avatar
CelticOne
Regular User
3X on the float stuck (or developed a pin hole, filled with fuel and sunk - like mine did).
Old Dec 25, 2019 | 01:12 PM
2dwoods's Avatar
2dwoods
The flooded fuel can run down and dilute oil
Old Dec 25, 2019 | 03:02 PM
broktruk's Avatar
broktruk
Stuck float. Corroded float pivot, float full of fuel, dirt in the seat. Electric fuel pump? If so, maybe needs a regulator. Manual choke...sometimes we learn the hard way to check its position.
Old Dec 25, 2019 | 06:45 PM
Ozzie H.'s Avatar
Ozzie H.
It "might" help to know year, engine, and carburetor involved. It doesn't seem like it should have done permanent damage to the carburetor, but it definitely would have flooded the engine and prevented it from starting. You might want to remove one spark plug and see what it looks like. Give us a bit more information and perhaps we can do better.
Old Dec 26, 2019 | 11:50 AM
alans77crew's Avatar
alans77crew
if Motorcraft or Holley could be accelerator pump
Old Dec 27, 2019 | 04:08 PM
catfishpizza
It's a 1973 F100, 360(not sure) with a Holley 2B. Hit the carb with a rubber mallet. Started right up. Thanks for the tip! Now it is still leaking gas and leaks more gas with throttle. Guessing I need to pull it and rebuild.
Old Dec 27, 2019 | 05:56 PM
catfishpizza
Short video of gas leaking. Enjoy.
File Type: mov
Old Dec 27, 2019 | 06:29 PM
FuzzFace2's Avatar
FuzzFace2
You took the video a little to close& short to see what carb but it looks to be a Holley and it looks to be the accel pump leaking.
I would say get a rebuild kit for it and pull it a part give it a good cleaning and new gaskets.
The gaskets dry out from sitting and to fix yours you would need the accel pump and a bowl gasket.
Dave ----
AntiHero55
Aug 28, 2010 09:11 PM
jerod2099
Mar 29, 2007 09:45 PM
openscars
Feb 16, 2005 12:32 PM
betatrone
1978 - 1996 Big Bronco
Mar 28, 2003 01:03 PM
ford429cu
Nov 28, 2002 10:10 PM
