HELP!!! Holley 4180
Old Feb 15, 2005 | 05:36 PM
openscars's Avatar
openscars
HELP!!! Holley 4180
Ive just installed a holley 4180 w/ an edelbrock performer 400 intake on my 79 bronco. i drove it all day yesterday and it ran great. I started it up this morning and it bogged down when i hit the gas. It also decided to backfire out the exhaust and carb
First, how would i tune the carb?
Second, what would cause it to backfire?
Old Feb 15, 2005 | 05:47 PM
lee's Avatar
lee
Ok,
Did it do this bogging down and backfiring when you first cranked it up?
Did it stop after the engine warmed up?
If "yes" then I would look at the choke. When cold the choke may be closed too far.
Lee
Old Feb 15, 2005 | 05:50 PM
openscars's Avatar
openscars
i let it warm up for about 15 mins. then went to leave and i hit the gas and it backfired and bogged. i let it sit for awhile and the same thing keeps happening.
Old Feb 16, 2005 | 10:28 AM
lee's Avatar
lee
Ok,
After it gets up to temp, blip the gas to get the carb off of the high idle. Then pop the lid on the air cleaner and verify that the choke butterly is open all of the way.
Also, is this a new carb or,..... rebuilt? Do you know it's history? In other words is this a known good working carb?
Check and make sure that the accel pump linkage is adjusted correctly.
Lee
Old Feb 16, 2005 | 10:54 AM
openscars's Avatar
openscars
this is a used carb it was working fine on my friends truck. how would i adjust the accel. linkage?
Old Feb 16, 2005 | 12:32 PM
beartracks's Avatar
beartracks
You might have gotten some dirt in the inlet valve. This will cause flooding, high float level.
chcknugget
41
Oct 10, 2012 08:50 AM
Chumbucket
Mar 18, 2008 02:56 PM
vito
May 4, 2005 07:24 PM
HiDesertRat
Jul 19, 2004 09:34 AM
tcd
Jul 6, 2004 11:34 PM
