Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2006 Ford Escape tpms issues
Old Dec 21, 2019 | 02:27 PM
TexGuy's Avatar
TexGuy
I have a 2006 Ford Escape V-6 4wd. I have a low tire light on and tried to reset with a reset tool. It took several trys to get it into the reset mode and still have a low tire light on. All 4 tires did beep the horn, any suggestions?
TexGuy
Old Dec 21, 2019 | 10:10 PM
DBGrif91's Avatar
DBGrif91
Is the light flashing or on steady? If it’s flashing, it’s a problem with one of the sensors that can’t be fixed by a reset/relearn procedure (the batteries are usually at fault). If it’s on steady, it’s a tire pressure issue.
What pressure are you setting them to? Check the sticker on the driver door jamb for recommended pressure - if they’re already set there and the light is still on, try setting them 2-3 PSI above the recommended pressure.
Also, if you haven’t tried, drive it a few miles - sometimes the pressures won’t transmit until the vehicle is in motion.
Old Dec 22, 2019 | 07:04 PM
TexGuy's Avatar
TexGuy
I'll start with the right rear tire as I suspect that the one. The light is a steady glow at all times.
Old Dec 28, 2019 | 09:34 AM
TexGuy's Avatar
TexGuy
I went out yesterday to check the tires, the driver side tires had 20 PSI of air, So this morning at 7AM I was back at Walmart shop that told me last oil change my tires had been check. They took me right in and air up my tires, 2 PSI over the sticker on the door to 32 PSI The low tire light is off now but the good news is they are reset.
Old Dec 28, 2019 | 01:00 PM
DBGrif91's Avatar
DBGrif91
Don’t be surprised if the light is on again tomorrow and there’s a difference of a few psi - temperature has a pretty significant impact on pressure and tires start heating up as soon as you start driving. That’s why it’s best to check and adjust the pressures when the tires are cold because the temperature has stabilized.
20 psi is pretty low so there might be leaks - check the pressures each day before driving to monitor. If there is a leak, those tires will get consistently lower each day.
You could also raise the wheel off the ground and spray with soapy water or some kind of household cleaner like 409 or windex - bubbles will form around a leak.
Old Dec 28, 2019 | 01:12 PM
TexGuy's Avatar
TexGuy
I've been thinking of a reason to start going to NTB for oil changes, I think this is it.
Old Dec 28, 2019 | 01:45 PM
DBGrif91's Avatar
DBGrif91
While I’ve heard many a horror story about Walmart’s auto dept, it’s important to remember that the techs who work there are often inexperienced and the demands of chain auto service centers (Walmart/Sams Club, Mills Fleet, Jiffy Lube, Midas, etc) are oftentimes overwhelming. They’re expected to perform like top level techs when they’re just not ready or equipped to do so.
I’ve been a tech for 3 years, I’m not on flat rate pay, and my boss is very understanding of how repairs can go sometimes; but even with all that, I still get overwhelmed because we’re always busy and at least a day or two behind schedule.
If you’re looking for a good shop, ask questions. Even if you know the answers, ask them anyway, because a good shop/tech will take the time to answer them whereas a bad one will be impatient and seem uninterested in you understanding the systems on your vehicle and how they work.
Old Dec 30, 2019 | 09:52 AM
TexGuy's Avatar
TexGuy
I'm calling it fix, it was in the 30's this morning and the tpms light is off. I'm still mad at Walmart over the tire issue.
Old Dec 31, 2019 | 01:00 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Glad you got it figured out. I'd stay clear of Walmart for anything. I've repaired countless friends' broken stuff from many Walmarts.
Torrance00
Mar 25, 2017 07:45 AM
BobbyJPhotos
2009 - 2014 F150
15
Dec 10, 2016 05:13 PM
ssmandavid
Feb 4, 2016 08:35 AM
leafswin
Dec 16, 2014 01:29 PM
50th ann
2009 - 2014 F150
Oct 25, 2011 09:40 AM
