Tire Pressure indicator Light
Old Oct 30, 2016 | 06:47 AM
BobbyJPhotos's Avatar
BobbyJPhotos
My 2012 F250 4x4 tire pressure warning message/warning light it on, I have checked all tire pressures, they seem fine, i s this a common problem and what normally has to be done to fix the issue and cost.., Thanks in Advance
Old Oct 30, 2016 | 07:20 AM
ubereal2's Avatar
ubereal2
Even a difference of 3 or 4 psi can make that light come on.
Old Oct 30, 2016 | 07:31 AM
BobbyJPhotos
Well thats kinda a pain in the A$$ then right...lol
Old Oct 30, 2016 | 08:12 AM
ttoptom1's Avatar
ttoptom1
Might check your spare tire-that caused mine to come on and kept rechecking pressures till finally was told by coworker he had same problem
Old Oct 30, 2016 | 08:18 AM
BobbyJPhotos
I havent got a spare, the dealer is working on getting me one(just purchased the truck 10-25)
Old Oct 30, 2016 | 11:14 AM
bigdaddyII's Avatar
bigdaddyII
That's likely where your problem lies. The spare is monitored and the system is sensing that it is missing.
Old Oct 30, 2016 | 06:27 PM
derek4343's Avatar
derek4343
If you plug anything into the charger or USB port it seems to set them off. I just unplug my phone and it goes out
Old Oct 31, 2016 | 10:09 AM
blhamon's Avatar
blhamon
Interesting on the spare. I recently took my truck on a trip to Colorado (from Omaha), and about 300 miles into the trip, I got a tire pressure sensor fault. I stopped at the next exit and checked the pressure and they were all set to 1 PSI over the setting on the door. I didn't even think to check the spare. The strange thing was, this happened several times during the trip, always after I had been driving several hundred miles, and the strangest thing. It just shut itself back off. I haven't seen it go off again since I've been home.
I'll check the spare and see what that says. Is the fault message the same as the low pressure light?
Old Nov 2, 2016 | 09:05 AM
BobbyJPhotos
Im not sure, lol, I have the light on and the message on the dash/display
Old Nov 25, 2016 | 03:38 PM
eriebasin's Avatar
eriebasin
I don't think the spare has a TPMS sensor.
Here is what's in the Owner's Manual:
Note: Each road tire is equipped
with a tire pressure sensor located
inside the tire and wheel assembly
cavity. The pressure sensor is
attached to the valve stem.
The pressure sensor is covered by
the tire and is not visible unless the
tire is removed. Take care when
changing the tire to avoid damaging
the sensor.
Old Nov 25, 2016 | 07:42 PM
Ranger Lance's Avatar
Ranger Lance
TPMS sensors run about $60. Discount Tire has a tool that will tell them if a sensor is bad.
Old Dec 9, 2016 | 12:12 PM
tractorboy924's Avatar
tractorboy924
I keep getting a light here and there too...NEVER thought to check spare!! will do but this time of year with temps air condenses so I can see it happening. and Ive heard too as you all have said they can be touchy.....
maybe the spare....damn.
Thanks
Old Dec 10, 2016 | 05:02 AM
hammer65's Avatar
hammer65
Mine came on the other day. Aired everything up to 35, except spare, itwas wet out so I didn't crawl under or let the spare down. Light stilled stayed on for some time, and then went out, as I was going down the road. Still out.
Old Dec 10, 2016 | 07:19 AM
cb_13's Avatar
cb_13
On most Ford systems the light is not suppose to go out until you've driven a certain distance at 25+ mph with the tires at the proper pressures. So yours are working as designed.
Old Dec 10, 2016 | 11:00 AM
eriebasin's Avatar
eriebasin
I'm pretty sure there is no TPMS sensor in the spare. The truck will only read 4 sensors. That's what the owner's manual means by "road tire." There are 4 road tires and 1 spare.
I've had 2 flats thus far. Each time, as long as the flat road tire was with me, the system indicated a low tire. Once I left the tire for repair, the system would eventually indicate a fault, not low tire; that's because it could not locate 1 of my 4 road tires.
